Intermittently I am having trouble connecting to the ISY and the plugin does not respond to Insteon devices. I see the message "No data for 120 seconds, network problem?." in the log during these times (and other times) usually it last only 30 secs or so and then I see the "ISY Heartbeat message" again. Sometimes the "no data for 120 seconds" lasts longer - up to a few minutes.
What are typical causes of this and any advice on trouble shooting would be greatly appreciated.
I'm running HS3 Standard Edition 3.0.0.280 (Windows) on Win7 machine
The ISY plugin Status Info is:
8/19/2016 2:45:23 PM
ISYInsteon Version 1.0
ISY: ISY 994i 1024 IR
ISY Firmware: 4.5.1
ISY Time: 8/19/2016 2:45:27 PM
Device Statistics
ISY Devices: 212
Unique Devices: 88
- ApplianceLinc 2456S3 V3.2: 1
- ApplianceLinc 2456S3 V4.2: 1
- FanLinc 2475F V4.1: 4
- Flex Your Power: 1
- Icon Dimmer 2876DB V3.9: 40
- Icon On Off Switch 2876S V3.6: 3
- Icon On/Off Switch 2876S V3.9: 1
- In-LineLinc Relay with Sense 2475S2 V4.1: 2
- Insteon LED Bulb Dimmer (915 MHz) 2672-222 V4.8: 1
- KeypadLinc 8-button Dimmer 2486DWH8 V4.0: 5
- KeypadLinc 8-button Dimmer 2486DWH8 V4.1: 2
- KeypadLinc On/Off (Dual-Band) 2487S V4.0: 1
- KeypadLinc On/Off (Dual-Band) 2487S V4.1: 8
- KeypadLinc On/Off 2487S V4.1: 1
- Micro Dimmer 2442-222 V4.3: 2
- Mini Remote - Switch 2342-222 V3.9: 1
- Motion Sensor - US (915 MHZ) 2842-222 V0.0: 1
- Outdoor ApplianceLinc 2634-222 V4.2: 1
- OutletLinc 2473S V4.2: 1
- OutletLinc Dimmer Dual-Band 2472D V4.0: 2
- OutletLinc Dimmer Dual-Band 2472D V4.1: 1
- RemoteLinc 2 Keypad, 8 Scnene 2444A2xx8 V0.0: 1
- SwitchLinc Dimmer Dual-Band 2477D V4.0: 2
- SwitchLinc Dimmer Dual-Band 2477D V4.1: 5
Scenes: 63
Programs: 330
Network Resources: 113
Modules: 2
Variables: 54
Weather data
Energy Monitor
Settings
HomeSeer Location: Do Not Set
HomeSeer Location2: Do Not Set
Location Separator:
Automatically add new devices: true
Type Descriptions: false
ISY Insteon Plug-in Log Level: Status Updates
Command Queue backlog: 0
Max Command Queue backlog: 0
Event Queue backlog: 0
Max Event Queue backlog: 352
ISY Firmware: 4.5.1
Device Statistics
ISY Devices: 212
Unique Devices: 88
Scenes: 63
Programs: 330
Modules: 2
Variables: 54
Weather data
Energy Monitor
Settings
Location Separator:
