Dirk
I figured I'd start a new thread since this is a different issue. My remote device is going offline and I'm not sure if it's because I'm running the plugin remotely on a windows box or is there some other issue.
Everything is hard wired. My TV is hard wired. HS3 is running as a Linux VM and the windows box is also a VM on the same subnet. If I restart the plugin, everything starts working. Firewall is disabled on my Windows system running the remote PI.
Thank you.
Thank you.
PS C:\program files (x86)\HomeSeer HS3> .\HSPI_MediaController.exe server=192.168.1.40
Connecting to server at 192.168.1.40 with Instance = '' ...
Connected, waiting to be initialized...
1/4/2017 10:22:47 PM : InitIO for Instance = found CurrentAppPath = C:\program files (x86)\HomeSeer HS3
1/4/2017 10:22:47 PM : InitIO for Instance = found HS running on Linux = True
1/4/2017 10:22:47 PM : InitIO Called for Instance = and running on OS = Win32NT
1/4/2017 10:22:47 PM : InitIO for Instance = found this plugin running on Linux = False
1/4/2017 10:22:47 PM : CheckLocalIPv4Address found IP Host = p-vwincctv01
1/4/2017 10:22:47 PM : CheckLocalIPv4Address found IP Address = fe80::895f:28c:5700:7760%12 with AddressFamily = InterNe
tworkV6
1/4/2017 10:22:47 PM : CheckLocalIPv4Address found IP Address = fe80::c12:1ee8:e740:bebd%14 with AddressFamily = InterNe
tworkV6
1/4/2017 10:22:47 PM : CheckLocalIPv4Address found IP Address = 192.168.1.21 with AddressFamily = InterNetwork
1/4/2017 10:22:47 PM : CheckLocalIPv4Address found IP Address = 2001:0:d5c:5a30:c12:1ee8:e740:bebd with AddressFamily =
InterNetworkV6
1/4/2017 10:22:47 PM : GetLocalIPv4Address found IP Host = p-vwincctv01
1/4/2017 10:22:47 PM : GetLocalIPv4Address found IP Address = fe80::895f:28c:5700:7760%12 with AddressFamily = InterNetw
orkV6
1/4/2017 10:22:47 PM : GetLocalIPv4Address found IP Address = fe80::c12:1ee8:e740:bebd%14 with AddressFamily = InterNetw
orkV6
1/4/2017 10:22:47 PM : GetLocalIPv4Address found IP Address = 192.168.1.21 with AddressFamily = InterNetwork
1/4/2017 10:22:48 PM : GetLocalIPv4Address found Local IP Address = 192.168.1.21
1/4/2017 10:22:48 PM : GetLocalIPv4Address found IP Address = 2001:0:d5c:5a30:c12:1ee8:e740:bebd with AddressFamily = In
terNetworkV6
1/4/2017 10:22:48 PM : InitIO Called for Instance =
1/4/2017 10:22:48 PM : Media Controller Plugin Initialized
1/4/2017 10:22:50 PM : FindUPnPDevice: Attempting to locate all connected. This may take up to 9 seconds.
1/4/2017 10:23:29 PM : FindUPnPDevice - Discovery succeeded: 7 UPnPDevice(s) found.
1/4/2017 10:23:29 PM : InitIO Called for Instance = 23456789-1234-1010-8000-104fa8d26af2 and running on OS = Win32NT
1/4/2017 10:23:31 PM : ConnectionManagerCallBack added for device = XBR-75X940D
1/4/2017 10:23:31 PM : AvTransportCallback added for device = XBR-75X940D
1/4/2017 10:23:31 PM : CreateUPnPControllers created an instance of UPnPDeviceController for UPnPDevice = XBR-75X940D
1/4/2017 10:23:31 PM : InitIO Called for Instance = 0dae28f8-46e4-4685-a045-b45aa9327e4b and running on OS = Win32NT
1/4/2017 10:23:32 PM : CreateUPnPControllers created an instance of UPnPDeviceController for UPnPDevice = Family Room TV
1/4/2017 10:23:33 PM : InitIO Called for Instance = 22d14f77-b8b5-45c3-a1bb-c1218fcc3bb2 and running on OS = Win32NT
1/4/2017 10:23:35 PM : CreateUPnPControllers created an instance of UPnPDeviceController for UPnPDevice = Family Room TV
1/4/2017 11:22:54 PM : IPAddress for UPnPDevice = Family Room TV has changed. Old = 192.168.1.42. New =
1/4/2017 11:23:14 PM : Reachable called for UPnPDevice Family Room TV which is not reachable anymore and set Off-line
tworkV6
tworkV6
InterNetworkV6
orkV6
orkV6
terNetworkV6
