Originally posted by Stevieboy
View Post
Then follow these instructions from the first post of this thread:
Place it in your HS3 directory. Run it once to create the HSPI_RSFindMyDevice.xml config file.
Edit the file(.xml) and set the following values: This is your itunes account
<Username></Username>
<Password></Password>
Set the API key if you want maps and reverse geolocation - you can get to the API from this link: https://console.developers.google.com
<GoogleApiKey></GoogleApiKey>
The API must be enabled for the following services:
Geocoding API
Static Maps API
Restart the plugin.
All geo coordinates are logged to the HSPI_RSFindMyDevice.csv file in the Log directory. This file is updated every minute.
Plugin must be stopped when editing the xml file.
Geocoding API
Static Maps API
Restart the plugin.
