Hi, ever since I setup homeseer hs speak has been very disappointing. I have yet to get it working correctly for the past 2 years. *If* I can actually get it to speak an event after restarting the server and re-selecting the correct soundcard, it will usually only speak a couple events and then I usually never hear anything again unless I repeat the same process above and even then its a 50-50 shot at best. However, if I create a manual speaking event and trigger it, that usually works and android connected clients do seem to work most of the time consistently I do always see the text that was spoken in the hs speak log. It seems like automatically triggered speaking events stop playing over the speaker. I am at a loss at this point and I am hoping I can get some help from the forum. My setup is as follows; quad core,4gb ram windows server 2012 r2 brand new install, with 10 usb c-media cm119 chip sound cards, connected to 10 amps and speakers, running 10 concurrent sessions of squeezelite for zone audio. homeseer also runs on this server and only one hs speak client is running locally. I have disabled exclusive mode on all sound cards, disabled zoned audio, tried running hs speak events via script and the built in speak action in homeseer. what am I doing wrong?
HS Speak just stops speaking
i have another example of the problem. yesterday, 3 speaking events triggered fine, after that i heard nothing. locally from the server i ran a test speaking event manually, i heard the speech in the proper room just fine. i purposely triggered two more speaking events, they worked fine as well, again on the next event after that i stopped hearing the speech audio. it makes no sense, and its really disappointing after spending 30 minutes here, an hour there working on this with no results for over a year now. This really sucks.
Originally posted by sparkman View PostAre you using the SqueezeBox plugin as your speech proxy?
Cheers
Al
Any other ideas, anyone? I tried select the speaker client for the speech action but that doesn't see to stay working either. What is interesting is if I run my manually triggered speech even, it always seems to work consistently, but when an even is triggered with speech that is setup the same way it does not speak on the speaker.
I take it that the lack of response is because know knows anything about hs.speak for some reason I guess not even the developers? Anyway moving on since I have no way to make speech work automatically when an event is triggered even after reformatting and reinstalling windows 2012 r2 and homeseer only, I guess I have to move on to make speech work another way. I am trying to use squeezebox proxy and the client shows the audio url is playing but there is no sound. Heres the log file for it if anyone cares. I did not see any errors in the log file, but I could easily be missing something.
Jan-09 3:18:03 PM SqueezeBox Debug Exiting speechTimer_Elapsed Jan-09 3:18:03 PM SqueezeBox Debug Exiting SpeakOutNextInQueue. New status: stopped. PendingSpeechTrackEnd: False Jan-09 3:18:03 PM SqueezeBox Debug StopSpeechTimer. Jan-09 3:18:03 PM SqueezeBox Debug Entering DisableSpeaking Jan-09 3:18:03 PM SqueezeBox Debug SpeakOutNextInQueue - Stopped. Jan-09 3:18:03 PM SqueezeBox Debug Entering SpeakOutNextInQueue. Status: stopping. PendingSpeechTrackEnd: False Jan-09 3:18:03 PM SqueezeBox Debug Entering speechTimer_Elapsed Jan-09 3:18:02 PM SqueezeBox Debug Exiting speechTimer_Elapsed Jan-09 3:18:02 PM SqueezeBox Debug Exiting SpeakOutNextInQueue. New status: stopping. PendingSpeechTrackEnd: False Jan-09 3:18:02 PM SqueezeBox Debug StartSpeechTimer. Duration: 0:1:0 (1000) Jan-09 3:18:02 PM SqueezeBox Debug SpeakOutNextInQueue - Stopping. Jan-09 3:18:02 PM SqueezeBox Debug SpeakOutNextInQueue - Deleting TTS URLs. Jan-09 3:18:02 PM SqueezeBox Debug Entering SpeakOutNextInQueue. Status: started. PendingSpeechTrackEnd: False Jan-09 3:18:02 PM SqueezeBox Debug Entering speechTimer_Elapsed Jan-09 3:18:01 PM SqueezeBox Debug Exiting speechTimer_Elapsed Jan-09 3:18:01 PM SqueezeBox Debug Exiting SpeakOutNextInQueue. New status: started. PendingSpeechTrackEnd: False Jan-09 3:18:01 PM SqueezeBox Debug StartSpeechTimer. Duration: 0:0:5 (5) Jan-09 3:18:01 PM SqueezeBox Debug Entering SpeakProxyUpdateDevices Jan-09 3:18:01 PM TTS Speak: (LMS:OFFICE):Want a bucket of chicken, buddy? Jan-09 3:18:01 PM SqueezeBox Debug SpeakOutNextInQueue - No LMS player as Client Speaker. Jan-09 3:18:01 PM SqueezeBox Debug SpeakOutNextInQueue - Added URLs: Jan-09 3:18:01 PM SqueezeBox Debug SpeakOutNextInQueue - SpeakProxy. Remaining Queue Length: 0 SpeakerClient: LMS Host: LMS:OFFICE Text: Want a bucket of chicken, buddy? Jan-09 3:18:01 PM SqueezeBox Debug Entering SpeakOutNextInQueue. Status: starting. PendingSpeechTrackEnd: False Jan-09 3:18:01 PM SqueezeBox Debug Entering speechTimer_Elapsed Jan-09 3:18:01 PM SqueezeBox Debug Exiting speechTimer_Elapsed Jan-09 3:18:01 PM SqueezeBox Debug Exiting SpeakOutNextInQueue. New status: starting. PendingSpeechTrackEnd: False Jan-09 3:18:01 PM SqueezeBox Debug StartSpeechTimer. Duration: 0:0:8 (8) Jan-09 3:18:01 PM SqueezeBox Debug Entering EnableSpeaking, Client: LMS:OFFICE Jan-09 3:18:01 PM SqueezeBox Debug SpeakOutNextInQueue - Starting. Queue Length: 1 SpeechAudioEnabled: False SpeakerClient: LMS Speak Host: LMS:OFFICE Jan-09 3:18:01 PM SqueezeBox Debug Entering SpeakOutNextInQueue. Status: stopped. PendingSpeechTrackEnd: False Jan-09 3:18:01 PM SqueezeBox Debug Entering speechTimer_Elapsed Jan-09 3:18:01 PM SqueezeBox Debug Exiting SpeakIn. Queue Length: 1 Jan-09 3:18:01 PM SqueezeBox Debug StartSpeechTimer. Duration: 0:0:4 (4) Jan-09 3:18:01 PM SqueezeBox Debug Entering SpeakProxyUpdateDevices Jan-09 3:18:01 PM SqueezeBox Debug Entering SpeakIn host: LMS:OFFICE, device: 0, Text: Want a bucket of chicken, buddy? , Enabled: True Jan-09 3:18:01 PM Event Event Trigger "Arriving/Leaving Home George is a buddy" Jan-09 3:18:01 PM Event Event Arriving/Leaving Home George is a buddy triggered by the event page 'Run' button.
You stated you were not using SqueezeBox plugin as your speech proxy but the posted log shows you are. You should disable this and get back to the basic speaker app and see if this works. Then reintroduce the speech proxy later once you have this working. You may also want to post this in the SqueezeBox forum so the plugin author sees this issue.
Originally posted by Rupp View PostYou stated you were not using SqueezeBox plugin as your speech proxy but the posted log shows you are. You should disable this and get back to the basic speaker app and see if this works. Then reintroduce the speech proxy later once you have this working. You may also want to post this in the SqueezeBox forum so the plugin author sees this issue.
Rupp, you have a good point. I already did start over from scratch twice, but both times I never tested hs speak with bare minimum. Anyway, I don't have a lot of time to try this a third time, so I went with squeebox plugin as a work around and I finally got it working on my own. The problem was the firewall. I had open port 80, 8080 incoming on the firewall on the homeseer server. I cannot believe that this was not mentioned any where. That's pretty scary imho. Hs speak still doesn't work. My best guess is it has something to do with squeezelite clients runnniong on the same system. Thanks to everyone who chimed in.
I personally have no clue because you are doing something unique.
While it is a great idea for multiple zones of audio it is not being done by most Homeseer users today.
Rupp mentions At this point it's time to simplify.
Using 10 USB sound cards and 10 instances of Squeezelite is pushing it for one computer.
I understand that a few users are doing this to get zoned audio and it works for them.
That said it not a typical methodology of created zoned audio/speaker.exe for Homeseer.
Simplify as Rupp mentions by trying your stuff initially with 1 then 2 then 3 sound cards.
It it doesn't work with one or two then something is amiss with your set up.
Ask the person who originally documented this methodology of using multiple sound cards for audio zones. (check also the hardware CPU / Memory and OS he is running).- Pete
R U Administering Server Remotely?
Ok, this may be way off, but are you administering your HS3 remotely via RDP? And if so, are you breaking off the remote session by just shutting down the RDP?
In my case if I do it the conventional way I lose the speaker.
Somewhere on this board, quite a while back, I found a post that said to use the following command in a shortcut (on the HS3 server) to break off the session:
C:\Windows\System32\tscon.exe 1 /dest:consoleRegards,
Chris
HS4 Pro 4.2.18.3 Shuttle DL10J - Celeron - 8g Ram - 250g SSD / Win 10 Pro 64 / Insteon / Z-Wave & SmartStick+ / DSC 1832 - PC5108 - IT100 / 542 devises & 164 events
Plug-Ins: AK Weather 4.0.5.58 / APCUPSD 3.3.2.3 / BLDSC 2.0.68.0 / BLMarantz 2.0.6.0 / BLShutdown 1.0.4.0 / Blue-Iris 3.1.3.33206 / Device History 3.1.3.0 / HSBuddy 3.30.1003.1 / Insteon 3.0.7.2 / weatherXML 3.0.11.13 / Z-Wave 3.0.10.0 / Z-Wave UI 1.0.0.0
