This thread is for discussions related to build 3.0.0.362 of HS3.
Discussions related to HS3 build 3.0.0.362
Dang, I modified the build script to automatically clean the files, I guess it did not work. I cleaned the files and uploaded a new tar file.
Originally posted by stefxx View PostThe Linux version includes (again!) too many files, overwriting the HomeSeerData.hsd file, settings.ini and other files. Luckily I have a backup...
My last backup was from 10 days on build 350 so not too bad recovering. I guess that since the 357 update went flawlessly I got a little cocky.
I see that something is not right, I took down the update and am looking into it.
Originally posted by andyf View PostI updated my Linux system from 357 using the updater in Setup. Pandamonium. All of my plug-ins error out. Hung the browser when I tried to disable them, nothing worked.
Just go back to 357, there is a problem with the Scheduler.dll file in 362, no other existing files are corrupted.
Originally posted by concordseer View PostToo late. Already updated to .362. Plugins disabled and plugin server just aimlessly spinning around.
Much better, thank you. However, with 363 I get an error during startup and the error repeats every 25 seconds or so:
Code:08:06:05:3626:[HSTouch Server]->Server started on port 10200 08:06:05:4034:[Startup]->HStouch server started, waiting for clients to connect. 08:06:05:4288:[Web Server]->Local IP address is: x.x.x.x 08:06:05:4349:[Web Server]->Web Server started on port 80 08:06:05:4384:[Web Server]->UPNP Discovery started 08:06:05:4660:[Startup]->Start automation engine... 08:06:05:4707:[Startup]->Initializing Speaker Client Interface 08:06:05:4811:[Speech]->Listening for remote speaker connections on port 10401 08:06:05:4953:[Database]->Opening (Mode=Read/Write) up HomeSeer Energy database /HomeSeer/Data/Energy/Energy.hsd Program exception: 20-9-2017 08:06:05 Specified cast is not valid. HomeSeer version: 3.0.0.363 Source: Scheduler Target: Void cfd126dc22649054e668c25ba373a0e5a(System.Object) Stack trace: at A.ccbdc96391d2f873f9c7f76d835409e30.cfd126dc22649054e668c25ba373a0e5a (System.Object cc1a76d1c59261e22fedcb6b19068e3d5) [0x00000] in <649533d281fe4dfd9808382ecdcd26d7>:0 at System.Threading.ThreadHelper.ThreadStart_Context (System.Object state) [0x00025] in <204f770036d441bb8dfd3daba3550e83>:0 at System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, System.Boolean prese$ at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, System.Boolean preserveSyncC$ at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state) [0x0002b] in <204f770036d441$ at System.Threading.ThreadHelper.ThreadStart (System.Object obj) [0x0000f] in <204f770036d441bb8dfd3daba3550e83>:0 08:06:07:9481:[Startup]->Updater services starting... 08:06:07:9522:[Startup]->Starting Find service... 08:06:07:9623:[Startup]->Powerfail Recovery will take place in 30 Seconds
stefxx
Hi
On this specific flavour (HS3:3.0.0.362 on windows10) I experiment a fairly high cpu use about 25% on a fresh boot. It remains constant with time. Very few activity on HS3 engine.
I didnt check for a while, I did it in that case, hearing at my laptop spinning up the fans.
JMJ09
Computer: ASUS K52F
CPU: Intel Core i3-380M (Arrandale SV, K0)
2533 MHz (19.00x133.3)
Motherboard: ASUS K52F
Chipset: Intel HM55 (IbexPeak-M DH)
Memory: 4096 MBytes @ 532 MHz, 7.0-7-7-20
Drive: ST9320325AS, 312.6 GB, Serial ATA 3Gb/s @ 1.5Gb/s
Network: Atheros AR9285 Wireless Network Adapter [AzureWave]
Network: JMicron Technology JMC250 PCI-E Gigabit Ethernet Adapter
OS: Microsoft Windows 10 Professional Build 16288
HS3
Current Date/Time: 20/09/2017 10:33:15
HomeSeer Version: HS3 Pro Edition 3.0.0.362
Operating System: Microsoft Windows 10 Professionnel - Work Station
System Uptime: 0 Days 0 Hours 8 Minutes 22 Seconds
IP Address: 192.168.1.78
Number of Devices: 133
Number of Events: 49
Available Threads: 400
Enabled Plug-Ins
30.0.0.35: RFXCOM
3.0.1.144: Z-Wave
Guest
