Go Back   HomeSeer Message Board > General Home Automation > Off Topic
Off Topic Post your jokes, funny stories, current events and antecdotes here.
  #21
Old March 19th, 2017, 10:35 AM
rprade's Avatar
rprade rprade is offline
OverSeer
Quote:
Originally Posted by sparkman View Post
That was a pretty common way of wiring split kitchen outlets and was allowed by code. The expectation was that only the unbalanced load was carried on the neutral. It is still allowed by code in many jurisdictions.
Cheers
Al
I am sure it was up to code at the time and for all I know may be still. Nevertheless, in the kitchen with one leg supplying the dishwasher and another to 20A outlets that could potentially have a coffee maker and/or toaster oven, that neutral could be carrying 30+ amps of continuous load. Both of us know that a 12AWG wire could probably handle that without catastrophic failure, it still is not the way I would want it wired. It would also have to be the perfect storm of brewing coffee, making toast and the dishwasher on the drying cycle befour the neutrals limitation would be a factor. At a minimum there could be substantial voltage drop to all of the appliances.
Randy Prade
Aurora, CO
Prades.net
PHLocation - Pushover - EasyTrigger - WeatherXML - UltraECM3 - Ultra1Wire3 - Arduino
  #22
Old March 19th, 2017, 10:43 AM
ewkearns's Avatar
ewkearns ewkearns is offline
Seer Deluxe
Quote:
Originally Posted by racerfern View Post
It would be interesting to see fire department data for that neighborhood since it was built.
AFAIK, no problems, there. This was 'homeowner repair" either contracted out to the incompetent or made by the previous homeowner himself, who owns a repair shop and should know better.
He had a penchant for hiring idiots. The brick patio with an underlayment of mulch. The sprinkler system with the valves buried without benefit of boxes. The HVAC system with one enormous plenum fabricated out of Insulboard and fed into what looked like a herd of Snuffleupagi babies nursing from their mother....
Finally, I think I have fixed nearly all of his "improvements."
HomeSeer Version: HS3 Pro Edition 3.0.0.318
Enabled Plug-Ins:
2.0.46.0: BLBackup, 2.0.22.0: BLUPS, 1.1.2.0: Device History, 3.0.0.75: HSTouch Server, 3.0.1.83: PHLocation, 3.0.5725.16923: UltraCID3, 3.0.5917.35093: UltraLog3, 3.0.6260.19461: UltraMon3, 3.0.0.63: weatherXML, 3.0.1.94: Z-Wave, HS Touch Designer: 3.0.50
  #23
Old March 19th, 2017, 10:47 AM
sparkman's Avatar
sparkman sparkman is offline
OverSeer
Quote:
Hi Randy, because the two legs are out of phase, the current flows will be out of phase as well. Assuming purely resistive loads, the current in the neutral for the two phases will cancel out. So if you had a coffee maker drawing 10A on one phase and a toaster drawing 6A on the other, the current on the neutral would be 4A, not 16A. Most loads won't be purely resistive so the currents won't be perfectly out of phase, but most of it will be cancelled out.
Cheers
Al
HS3Pro 3.0.0.318 on Jetway JBC501F9Q-Q87-B i7 8GB 1899 Devices, 954 Events, 28 Plugins
Z-Wave 3.0.1.112 Z-Net 105 nodes:Leviton Vizia,Kwikset,FortrezZ Valve/Sensors,Everspring Sensors/Modules/Outlets,CT30 Stats,MIMOLites,Aeotec Smart Switches
RFXCom W800,RFXrec433,RFXtrx433|APCUPSD|Pushover|Squeezebox|weatherXML|HS Phone W2C|APCUPSD|UltraLog
UltraGCIR GC-100|UltraNetcam|UltraPioneer|Ultra1Wire|DSC PC1832|BLLED|BLTVGuide|ImperiHome|jon00 Utilities|MySensors
PHLocation|X10 CM11A IOLinc,etc
  #24
Old March 19th, 2017, 12:05 PM
rprade's Avatar
OverSeer
Cheers
Al
I didnt think that through, but you are correct. They are wired to different phases - as long as someone doesn't screw up the connections in the breaker panel. I still don't like it.
  #25
Old March 19th, 2017, 12:22 PM
sparkman's Avatar
OverSeer
Most of the ones I have seen (including in my own houses) used double breakers so that guaranteed that both phases were used.
Cheers
Al
  #26
Old March 19th, 2017, 01:04 PM
rprade's Avatar
OverSeer
Cheers
Al
Mine doesn't, but both runs did use adjoining pairs of breakers. That still could allow some stupid head to connect the two wires to breakers on the same phase
HTML code is Off
What's the worst-case real-world "cost" of z-wave polling? NeverDie HomeSeer Z-Wave Plug-in 3 March 1st, 2014 03:38 PM
X-10 Pro Tech Support is the WORST EVER chijohnh Lighting & Primary Technology Discussion 3 November 3rd, 2010 07:46 PM
Re-install nightmares! b50int HS2 / HSPRO 4 June 5th, 2008 06:52 AM
Possibly the worst documentation ever? Slacker TouchPad 11 October 19th, 2005 12:16 AM
Wiring for ADICON Modules and TEMP08 Wiring Jim Doolittle General Home Automation Hardware Discussion 10 August 5th, 2004 02:46 PM
