@Mark...
Noticing the following that cropped up in the debug logs as of yesterday using V.40 of the plugin.
Note that this is relating to using the CM11A (batteries removed) only plugged in to the old XTB amplifier with the CP303 X10 noise blocker connected.
I never saw this before.
That and I am still here on Homeseer 3 Pro V.290 and seeing many many updater errors now in the logs. Wondering if that has anything to do with this.
Noticed too a new value in the X10 ini file that I didn't see before.
[settings]
PluginDebug=True
Override=False
[Default]
Protocol=0
PollInterval=300
ignorehcstring=0111111111111111
Mar-14 7:11:36 AM X10 ERROR error in GetUpload :Argument 'Length' must be greater or equal to zero
Mar-14 7:11:48 AM X10 DEBUG CM11A Upload byte count: 2
Mar-14 7:11:48 AM X10 DEBUG CM11A Upload Data: 1 Time: 25908.935
Mar-14 7:11:48 AM X10 ERROR error in GetUpload :Argument 'Length' must be greater or equal to zero
Mar-14 7:11:50 AM X10 DEBUG CM11A Upload byte count: 2
Mar-14 7:11:50 AM X10 DEBUG CM11A Upload Data: 1 Time: 25910.872
Mar-14 7:11:50 AM X10 ERROR error in GetUpload :Argument 'Length' must be greater or equal to zero
Mar-14 7:11:52 AM X10 DEBUG CM11A Upload byte count: 2
Mar-14 7:11:52 AM X10 DEBUG CM11A Upload Data: 0 Time: 25912.335
Mar-14 7:12:03 AM X10 DEBUG CM11A Upload byte count: 3
Mar-14 7:12:03 AM X10 DEBUG CM11A Upload Data: 3 Time: 25923.991
Mar-14 7:12:03 AM X10 ERROR error in GetUpload :Argument 'Length' must be greater or equal to zero
Mar-14 7:12:06 AM X10 DEBUG CM11A Upload byte count: 2
Tinkering some more here removed the old XTB amplifier, left the CP303 blocker in place which the CM11A was plugged in to and deleted the last line in the X10.ini file:
ignorehcstring=0111111111111111 such that the X10.ini file looks like this:
[settings]
PluginDebug=True
Override=False
[Default]
Protocol=0
PollInterval=300
and now debug logs show: (well one second response time and no errors)
Mar-14 7:29:13 AM Device Control Device: X10 X10-A X10-A1-Chime to On (100) by/from: CAPI Control Handler
Mar-14 7:29:13 AM X10 DEBUG CM11A Sending: 4 66 Size: 2
Mar-14 7:29:13 AM X10 DEBUG CM11A Got checksum: 6A
Mar-14 7:29:13 AM X10 DEBUG CM11A Checksum OK, sending 0
Mar-14 7:29:13 AM X10 DEBUG CM11A Got ack of: 55
Mar-14 7:29:13 AM X10 DEBUG CM11A Sending: 6 62 Size: 2
Mar-14 7:29:13 AM X10 DEBUG CM11A Got checksum: 68
Mar-14 7:29:14 AM X10 DEBUG CM11A Got ack of: 55
[settings]
PluginDebug=True
Override=False
[Default]
Protocol=0
PollInterval=300
[settings]
PluginDebug=True
Override=False
[Default]
Protocol=0
PollInterval=300
