Without to much work is there a way to monitor a (the) Windows Print Que events ?? IE Turn the device on when print que is loaded and turn printer off some time after the last print job completes... Maybe use the windows api calls ??? any ideas ???
Windows Printer Que ???
It's doable but depending on your level of code experience it may be a semi tough task. http://www.codeproject.com/vb/net/printwatchvbnet.asp
http://www.merrioncomputing.com/Prog...tchPrinter.htm
