Does this device exist anymore? I was thinking on expanding but cannot find the LAN version of the RFXCOM receiver...
RFXCOM lan device
RFXCOM lan device
HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.Tags: None
Well... that's too bad. I suppose I could also just use a USB LAN device as well. I'm looking to simplify as best as possible. The less complicated, the less to maintain.
RobertHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Can anyone recommend a LAN-USB adapter? I see some that plug into a usb and have LAN support. Essentially, I just want to plug a unit into my switch and service a USB connection to the RFXCOM receiver....HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
That makes that easy... PM sent!HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by langenet View PostCan anyone recommend a LAN-USB adapter? I see some that plug into a usb and have LAN support. Essentially, I just want to plug a unit into my switch and service a USB connection to the RFXCOM receiver....
One RFXtrx433E and one older RFXtrx433.
Originally posted by mfreese View PostI have two separate RFXCOM devices on two of these USB to LAN adapters http://www.silexamerica.com/products.../sx-ds-4000u2/.
@Automated, b_weijenberg does the device support a virtual com port or how is this device accessed?Last edited by langenet; March 6, 2015, 03:54 PM.HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by Automated View PostI have one of the RFXCom LAN devices that I might part with, but you would have to wait a few weeks as I am on business travel. PM me if interested.
ThanksHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by b_weijenberg View PostThe RFXLAN is no longer in the catalogue. Maybe later.
You use an RFXrec433, RFXtrx315 or RFX433E and connect it to a Raspberry PI with socat.
Linux cmd: socat tcp-listen:10001,fork,reuseaddr file:/dev/rfxcom,raw &
You can now connect the RFXCOM over LAN port 10001
Nov-10 12:18:01 AM RFXCOM 29 (CheckTransceivers) transceiver #2 info: resynced
Nov-10 12:18:01 AM RFXCOM Error: 29 (CheckTransceivers) packet timeout transceiver #2 State:21
Nov-10 12:17:55 AM RFXCOM 29 (CheckTransceivers) transceiver #2 info: resynced
Nov-10 12:17:55 AM RFXCOM Error: 29 (CheckTransceivers) packet timeout transceiver #2 State:21
Nov-10 12:17:53 AM RFXCOM 29 (CheckTransceivers) transceiver #2 info: resynced
Nov-10 12:17:53 AM RFXCOM Error: 29 (CheckTransceivers) packet timeout transceiver #2 State:21
Edit:
This is the line that worked for me:
/usr/bin/socat FILE:/dev/ttyUSB0,b38400,raw TCP-LISTEN:10001,fork,reuseaddr &
then stash it in /etc/rc.localLast edited by LeoS; November 9, 2015, 01:23 PM.HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Google Search for HomeSeer Forum
Update:
For some reason this solution is not reliable on my system. It seems to disconnect within 24 hours and doesn't properly reconnect.
I'm using this with 3 RFXtrx433, 3 raspberry pis and they all run socat exposing the rfxtrx as raw stream on port 10001. I had all three running quite solid with Digi USBAnywhere before this, but I prefer a driver-less solution if socat/raw connection is supported by the RFXCOM HS3 plugin.
Update 2:
Switched all 3 to ser2net. We'll see how it goes.
To install:
1. apt-get install ser2net
2. edit /etc/ser2net.conf with your favorite text editor (vi, nano, etc)
3. you can comment out the 4 ports that ser2net opens
4. add this line: 10001:raw:0:/dev/ttyUSB0:38400,NONE,1STOPBIT,8DATABITS
5. Run ser2net : /etc/init.d/ser2net start
6. adjust the settings on hs3 side to point to the new ip/ports.
Update 3: So far so good. It maintains connection so much better than socat and for some reason is also more responsive than socat on my setup.
Final update... 3 weeks later, and it's really solid and responsive. Really happy with the performance of this.Last edited by LeoS; December 9, 2015, 01:20 PM.HW: HS3 w/ Win8.1 on ASRock C2550d4i. Digi AnywhereUSB, Hubport, Edgeport, UZB, Z-trollers, PLCBUS, SONOS, GC-100, iTach IP2SL, WF2IR, IP2IR, RFXtrx433, Harmony Hubs, Hue, Ademco Vista 128BP, NetAtmo, NetAtmo Welcome
Act this moment I am also testing a rfxtrx433 connectie through WiFi. I am using a TP-link MR3020 with ser2net connected to my HS3 wifi network.
The first impressionist are looping good, but I am also seeing the resync error in my HS3 log.
I don't know of these massages are a problem, but the rfxtrx keeps working for now.
