Westinghouse Fan Problem
    I have an RFXrec433E with latest Ext2 firmware and am trying to control a Westinghouse Fan with HS3 but there is no response from the fan, just normal log entries as follows:
    Feb-11 07:25:21 RFXCOM 33 (SetIOMulti) set value: 0->ref:1185 ControlType:Button
    Feb-11 07:25:21 Device Control Device: RFXCOM RFXCOM Fan Master Bedroom to Off (0) by/from: CAPI Control Handler
    Feb-11 07:25:19 RFXCOM Error: 33 (decode_Chime) Sound = undefined sound:F
    Feb-11 07:25:19 RFXCOM 33 (SetIOMulti) set value: 147->ref:1185 ControlType:Button
    Feb-11 07:25:19 Device Control Device: RFXCOM RFXCOM Fan Master Bedroom to Light (147) by/from: CAPI Control Handler
    Feb-11 07:25:17 RFXCOM 33 (SetIOMulti) set value: 183->ref:1185 ControlType:Button
    Feb-11 07:25:17 Device Control Device: RFXCOM RFXCOM Fan Master Bedroom to High (183) by/from: CAPI Control Handler
    Feb-11 07:25:15 RFXCOM 33 (SetIOMulti) set value: 184->ref:1185 ControlType:Button
    Feb-11 07:25:15 Device Control Device: RFXCOM RFXCOM Fan Master Bedroom to Medium (184) by/from: CAPI Control Handler
    Feb-11 07:25:12 RFXCOM 33 (SetIOMulti) set value: 185->ref:1185 ControlType:Button
    Feb-11 07:25:12 Device Control Device: RFXCOM RFXCOM Fan Master Bedroom to Low (185) by/from: CAPI Control Handler
    I can control the fan with RFXmngr on its own (same com port) absolutely fine so I doubt that it is a problem with my RFXrec433E.
    In HS3 the Fan device appears to have been created correctly as per the attached pic, but there is no control via HS3.
Name:	Westinghouse Device.jpg
    The only other devices I'm using the RFXrec433E for are a Byron Bell and a Somfy blind.
    Both work perfectly.
    I'm on Win10 64 Bit.
    Any ideas anyone?
    I'm definitely on the right code as well, the default 0000...
    Again works fine in RFXMgr.
      This appears like its just not implemented properly in the plugin.
      Could anyone advise how to report it as a bug please?
        Contact support rfxcom.com for an updated plug-in.
