I have been having this problem pretty regularly for the past few months. After a day or two, the Insteon plug-in will decide that it can't communicate via the 2413U, and I will have to restart the plug-in. Restarting the plug-in works every time, but only for a day or two.
For a while I suspected it had to do with using the mobile app, as that's when the problem first started to appear, but I stopped using it for several days to test that out, and the problem still continues. Coincidentally (or not), the other thing that happened at that same time is I bought the software after the 30-day trial expired (I couldn't use the mobile app until I actually bought a copy of the software, which is why those two things happened at the same time). While on the trial I never had this problem at all, but since purchasing HS3 (the trial was HS3PRO), I've had this issue very regularly ever since. I had hoped the recent software update would help, but the behavior is still the same.
I am using version 3.0.0.318 of HomeSeer, and 3.0.6.0 of the Insteon plug-in.
