Has anyone tried to include any of these lately using Zwave 3.0.1.110 or 3.0.1.112 (or even later)? They include fine, and work except that they won't report properly if someone manually turns ON/OFF the outlet switch.
You will see the event in the event log, but the device itself, i.e.'Switch Binary', doesn't update. The Last Change time/date of the root node does change with the manual switching though. And from what I can tell, Watts, Volts, etc all report fine.
Downgrading to 3.0.1.87 makes seems to make everything work, but I need .110 to support some DOME stuff I've added.
Richard
Richard
