I am trying to add Aeon multi-sensor to homeseer. The sensor was added by z-stick, but there are no nodes for luminescence, humidity and temperature, only motion and battery.
In the log I get these errors:
4/20/2013 8:50:55 AM Error (2) Sensor Multilevel Report for type Temperature received, but the corresponding device Node ID cannot be found.(2) Node/Instance=12/-1
4/20/2013 8:50:55 AM Error (2) Sensor Multilevel Report for type Relative_Humidity received, but the corresponding device Node ID cannot be found.(2) Node/Instance=12/-1
4/20/2013 8:50:55 AM Error (2) Sensor Multilevel Report for type Luminance received, but the corresponding device Node ID cannot be found.(2) Node/Instance=12/-1
What should I do to get these nodes added to Homeseer?
