New user: Pi based zee. All up and running with Z-wave devices so far (indoor motion sensor turning on a outlet...gee...but it works).
I have the CM15a installed and to some degree working. I can turn my X10 wall switch on and off manually from the devices web page.
However, I have an X10 outdoor motion sensor that I have no idea how to detect. The sensor transmits to an X10 receiver (not the CM15a) that already existed and translates it to a powerline command for unit 2 on.
I also have an outdoor X10 flood light that is motion sensitive and when it turns on , it sends an "unit 2 on" command to my X10 wall switch. That is done thru the power lines.
I'd like to get it all under homeseer control so I can write more events. But I see no way to react to the X10 motion sensor, or detect the on command from the floodlight. Where do I start? I am just completely lost!
I would switch it all over to Z-wave, but amazingly, there seems to be no decent outdoor motions sensors! The X10 outdoor motion sensor works perfectly, dusk to dawn, adjustable delay, etc. Can't believe there is not a similar Z-wave device that works well!
So, please how do I get started seeing my X10 wireless motion detector? And is there anyway to see commands in the log from X10?
Thanks so much!
Thanks so much!
