ADIO-100 volt not appear; output not working
    ...actually nothing much is working.
    Not sure why there's not a ADIO-100 sub-forum. Since Homeseer sells this.
    Anyway, I just got it and hooked it up. Problems:
    -Left side 5vdc reference to ground shows 5v (no duh)
    -Right side 5vdc reference to ground _not_ showing anything (0v); doesn't matter which 5vdc or which ground on the right side (of course I checked the seating of the connector)
    -Config'd Bit0 and Bit7 as output; use Dev Mgmt to turn them on; log verifies; zero volts on either bit referenced to Gnd; it should show 12v (I'm assuming)
    -Tie Analog Chan7 to 5vdc. Turn it on in the plug-in manager. DevMgr shows blank; no log entry; but...
    -If I disconnect that jumper, DevMgr shows 0
    Defective unit? The plug-in appears to work fine (hence not posting there).
    Thanks.
    Tahl
