Spud,
Wanted to know how you handle the different instances (multiple kinects) using events.
I have installed 2 kinects, 1 on HS computer and 1 on remote.
This creates 2 instance and 2 global variable pools. I am setting up events for "A Phrase Was Recognized" and have to choose which kinect to run event. I am scripting all the actions using global variables so I dont have to have a ton of events (IE.. Turn <Office|Dining|Pool|Spa|Kitchen> Lights <On|Off>. Which means I have to use the correct global variable for that instance. (kinectofficevar0 or kinectvar0)
So my quesition is what is the best way to handle multipl kinects without having to create an event for each kinect to run the same event?
I am new to HS and still tring to get my feet wet, but this is a great plugin, works 10X better than HS Speak for voice recognition, I look forward to all the cool things I can do now. Also I use your DirecTV plugin - keep up the great work and let me know anytime you need a tester for products as I can code/create scripts and push the plugins to help find issues
Steven G
Steven G
