Omni connection issue
    I have homeseer set to DHCP could this be an issue?
    no.
    Do you have the capability to flash update your Omni Board?
    If you can I would update it to most current level of firmware and update PCA to most current level of software.
    [ATTACH]64046[/ATTACH]
    Note that the update of firmware and software has nothing to do with the Homeseer 3 Omni Plugin.
    The plugin should work fine with HAI firmware 3.16.
      Ok, from the last screenshot, you have an Omni LTe-EU - I should have paid more attention to your location
      So, the european version of the panel must be a much different type than what I have.
      I need to open a ticket with Leviton on this issue. Might be a while before I hear back, but I'll report back as soon as possible.
      HS4Pro on a Raspberry Pi4
      HSTouch Clients: 1 Android
        Here test created a new account and this is what it shows when I do that.
        [ATTACH]64047[/ATTACH]
          apologies i should have said it was the EU version.It seems im on version 3.16 have found 4.0b should i install this??
            I would wait until I hear back from Leviton.
              #21
              yes the one i have is the 3rd one down Omni LTe-EU
                #22
                Ok thanks for the help, how long does a reply from leviton normally take? days or weeks?
                  #23
                  It's hard to say - they are usually responsive in a day or so. Depending on what the eventual fix is, I have no idea - could be a simple fix or something more complicated. I'll reply back to this thread when I hear something.
                    #24
                    Just had a thought, think i may have the HomeSeer HomeTroller Zee S2 (UK) version and not the EU version. i guess this would be the issue however i am unsure where i would find the information of the controller.
                      #25
                      I just heard back from Leviton and it seems that the SDK does not support the EU version of OMNI controllers. They are evaluating what it would take to add that functionality.
                      If you purchased a license for the OMNI plugin, get in touch with HST for a refund.
                      I'll post more info as I hear from Leviton.
                        #26
                        Weird that Leviton saids that the SDK doesn't support EU versions of the Omni Controllers.
                        This stuff was posted back in 2012 such that I have no clue about it today in 2017.
                        Leviton has updated the firmware a few times now along with PCA. They did skip stuff writing new pieces for the email board, Omnitouch screen and left out pieces from the old Omnitouch screen (video pop ups) which they since corrected with current 4.X firmware.
                        I am not sure that Fred from HAI is still around these days.
                        In 2012 Fred of HAI wrote that any model supported in PC Access was also supported by the SDK.
                        First let me say that the SDK works with all models of HAI and HAO/OEM controllers. This is the same code that is used by all of our own products just in a DLL wrapper, so anything and any model supported by PC Acceess 3 is supported by the SDK.
                        More stuff....not really sure if this helps....
                        if (HAC.Model == MSG.ModelNumber)
                        Right before that line of code, add this:
                        foreach (enuModel enu in Enum.GetValues(typeof(enuModel)))
                                if (enu == MSG.ModelNumber)
                                    HAC.Model = enu;
                                    break;
                        so it looks like this:
                        clsOL2MsgSystemInformation MSG = new clsOL2MsgSystemInformation(HAC.Connection, B);
                                    HAC.Model = enu;
                                    break;
                          #27
                          That's interesting. Here is the email from their tech support:
                          Now, the code snippet in your email makes sense - I recognize that code from the SDK example and what is being used in the plugin.
                          I also found it odd that PC Access works but the plugin does not. PC Access is built using the SDK
                            #28
                            Thinking Leviton has subcontracted newbie CS Omni folks.
                            About a year ago opened up a ticket relating the the video CCTV pop up functions of the Omnitouch screens. The CS didn't know what I was talking about. I made him replicate the error and he understood for the first time. I opened up a support ticket and got a number but never got any email or closure on the ticket.
                            The error was fixed in subsequent firmware updates with no mention of it.
                            Much of the old customer base though used the function with their Omnitouch screens.
                              #29
                              Ok Pete so you think if I Wright this code in Homeseer it should work??
                                #30
                                No.
                                Current PCA version see's all domestic and international panels. This is been the same now going back to firmware V.2.X and same for all previous versions of PCA. AND PCA is based on current version of the SDK.
                                The guy above wrote a check to see what panel was connected and said that if the panel software checks and doesn't come back with a valid model then it is not in the SDK.
                                Fred answered that all of the panels are included in the SDK as the PCA software works with all of the panels and is based on current SDK.
                                @Peterborg,
                                What code are you writing about?
