Running Plugin Remotely
Test it on a RPi...just type
mono nameofplugin.exe server=ipofhomeseer server.
It'll utilize all of the configuration files on the Homeseer box.
If the plugin is configured to work in windows and linux this should work fine.
You will see the plugin come up as remote connection in the plugin manager page.
Should be the same with the AD2USB connection on a remote RPi.
I have historically tested this to work with X10, UPB, ZWave, Omni Panel plugins.- Pete
