A cheap way to make a dryer sensor is to use aeon labs whole house monitor ( on amazon for $24 ) and hook that in on the power lines going into the dryer. way cheaper than the other switches with sensing and easy to add.
How To Issue Washer - Dryer Alerts Using Energy-Aware Z-Wave Devices
Originally posted by collegeboyslive View PostA cheap way to make a dryer sensor is to use aeon labs whole house monitor ( on amazon for $24 ) and hook that in on the power lines going into the dryer. way cheaper than the other switches with sensing and easy to add.
Yeah i bought the single power monitoring z wave device... should.b here today. I will see which way I want to go for dryer
Sent from my Samsung Galaxy Note 3HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Keep in mind you'll either have to split the power cable and clamp the individual power lines or purchase parts to make your own pigtail to do this. keep in mind also that those units are very old HEM v1 sensors with old firmware.
open the back and the cable splits inside with room to add the clamps.
the software is fine to tell it the basic power output which is all you need to detect dryer running or notdetail of setup in profile. Link to videos of my projects there as well. Over 300 scripts running every min and counting
Here, using an aeon labs gen 1 ( $24 on amazon ) no need to the much more expensive gen 2 ) whole house power monitor as a dryer power sensor. you only need ONE of the 2 probes, , simply open the back access panned and hook the probe around the read or the black wire. run the probe wire out of the existing hole and replace the cover.
plug the sensor wire into the zwave module, link it to the zwave network and your done.. in 10 mins or less you can now see when the dryer is running ( power watts will be over 50 and when its off ( power watts will drop under 50 )
I used 50 as a mark as some modern dryers have circuity that pulls a small amount of power even when off. an older dryer with a mechanical timer you can it to anything over 0 , but 50 will also work just fine.detail of setup in profile. Link to videos of my projects there as well. Over 300 scripts running every min and counting
I setup the Washer the other day time to do the Dryer!!
this would work for the dishwasher also!
thanks guysHS3 Pro on Windows 8 64bit
53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
Check out my electronics blog here:
https://www.facebook.com/RaptorsIrrationalInventions
Originally posted by collegeboyslive View PostHere, using an aeon labs gen 1 ( $24 on amazon ) no need to the much more expensive gen 2 ) whole house power monitor as a dryer power sensor. you only need ONE of the 2 probes, , simply open the back access panned and hook the probe around the read or the black wire. run the probe wire out of the existing hole and replace the cover..
Dishwasher are 120v so you could just use a plug in aeon module.
Originally posted by Raptor View PostI setup the Washer the other day time to do the Dryer!!
thanks guys
Sent from my iPhoneTom
I put the aeon labs clamps around the dryer wires in the breaker box. I did the same for the stove and water heater.
So all three in one location and only took s few mins
Originally posted by macromark View PostPretty cool Zac! It's cheaper than a Heavy Duty smart switch, that's for sure!
Originally posted by collegeboyslive View PostHere, using an aeon labs gen 1 ( $24 on amazon ) .
I just snapped one up too. A quick and easy weekend project for the 240v dryer. If it works well, I will get a 2nd and replace the CurrentCost monitor that I can no longer interface with my HS machine, due to insufficient RF range and my inability to figure out how to extend the pseudo serial over USB thingy.cheeryfool
I ordered 2. It's a really good deal. The clamp-on current sensing transformers (CR3110) alone cost about $16 each from Digikey!
Steve Q
Sent from my iPad using Tapatalk HDHomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
I received the 2 Aeon Smart Energy Monitors I ordered from Amazon. I installed one of them on my HS2 setup and I plan to install the other one on HS3. It was a very good deal, but not quite what I expected. Over the years I have been watching the development of the Aeon z-wave product line, and I have purchased 2-Z Sticks, 2 multi sensors, and 2 door window sensors. So I have a little bit of experience with the product line. And I expected that I would have to consult the web for some of the Z-wave setup information. However...........
The product shipped from Amazon contained no helpful information. In fact, I doubt it contains the minimum labeling information required by law! Although it contains a large instruction sheet, nice for visually impaired users, it contains no information about: are batteries required, what type of batteries, how to install the batteries, the purpose of the Micro USB power adapter. etc! This lack of basic information is really irritating to me. But "you get what you pay for"!
The biggest surprise, was the size of the clamp-on current sensing transformers. I am very familiar with the CR3110A current transformer. I mistakenly thought the AEON device was using a private label version of this transformer; they look the same. However the AEON transformers are Huge! 4 times bigger than the CR3110a. Yeah they work, but not what I expected. All the pictures I have seen, give the impression of a fairly small device.
I think I got my money's worth, so I shouldn't complain.
I still have a lot more to do to fully utilize this device.
Steve Q
Sent from my iPad using Tapatalk HDLast edited by Steve Q; November 4, 2015, 09:54 AM.HomeSeer Version: HS3 Pro Edition 3.0.0.368, Operating System: Microsoft Windows 10 - Home, Number of Devices: 373, Number of Events: 666, Enabled Plug-Ins
