I generated a HS3 plugin to pull the motion detection alerts from HikVision cameras. The C# source is posted to GitHub, https://github.com/sgieseking/HSPI_HikAlarmCheck.
This is based on the example from aXis, http://board.homeseer.com/showthread.php?t=178122. The sample HSPI class has been changed to provide virtual functions so that you only need to override the functions that you need for your plugin. For a simple plugin, this is really only a few.
Like aXis, I found getting started with a C# plugin from the sample VB and the available C# templates was a bit difficult.
