I have 2 implementations of LED strip lights that I control via IR commands from HS3. I use The USBUIRT to send the signal to the strip lights. The lights come with a small IR remote which I use to manually control the LED lights.
Frequently, the lights get out of sync with HS3. They turn on when they should turn off, etc. I've tried the virtual device approach, but it also gets out of sync.
I'm pretty sure this issue is being caused by the distance between my IR emitter and the LED strip light sensor. But there is no way for me to get the emitter closer.
Any ideas on how to keep HS3 and the LEDs in sync?
Steve Q
Steve Q
