I have a Hometroller Zee S2 running the latest update (3.0.0.297).
I can connect to my HS-WD100+ dimmer but it only shows up as 1 device. I can control the dimmer but don't have access to the double and triple tap options. Any suggestions?
I want to use the double tap to control my front door lock.
I downloaded the latest firmware (5.14) for the HS-WD100+ but when I unzip it the file has a .hec extension not .hex as required by the controller. Do I just change the extension or is there something wrong with the download.
Chris
Chris
