So, I switched to using myHS instead of the built in server. However, now none of my devices are found. Is this normal? Do I have to rebuild my whole imperihome (like 15 pages worth)?
Changed to myHS, now my devices are all hosed?
Originally posted by spud View PostNo you shouldn't have to rebuild anything, unless you created a new instance of the plug-in to do the switch or unless you changed your HS3 machine name.
In the IH app system settings did you change the url and user/password, and did it successfully found your system after that?
I'm already over half way recreating all my screens. It was just a hassle. I didn't think it was necessarily your fault, but as of late, you are far more responsive than ImperiHome is.
So, I completely redid all my screens. and it all works locally using the new local address.
However, I can't access anything remotely. It goes back to telling me that none of my devices are there. When I try and edit the password, I get the message:
"You triee to connect to a different system by editing an exiting one. Please use the 'add a new system' wizard",
but it's not a new system. It's the same system. Why would it work locally, but not remotely? I double checked my myhs password and login and it should work.
Originally posted by spud View Postglad you got it to work.
I will see if I can reproduce this problem next time I test this part of the IH app.
The worst part was redoing all the custom images. Luckily had most of them still on my phone. IT did give me the opportunity to re-think the layout of some of my pages, so I guess something good came out of it
