What if you could have the ACRF processor read the incoming RF signal of a PalmPad, look up whether you want that X10 to pass to HS as an X10 command or have that surpressed, so that you could instead assign that RF command to launch an event. ?Then you could use palmpads to fire events without wasting an X10 house/unit code. Should work. Right?
Joe
Joe
