i have HS 2.2.0.11 , once i install and enable MCS sprinklers through the updater i do not have the MCS icon how do i go about the basic configuration of this plug in ?
plug in not working
joewireTags: None
joewire
forgot my log info
heres my log info
7/23/2007 5:23:24 PM - Startup -
7/23/2007 5:23:24 PM - Startup - ************************************************************ ********************
7/23/2007 5:23:24 PM - Startup - HomeSeer version 2.2.0.11 Starting Now (Standard Build)
7/23/2007 5:23:24 PM - Startup - Using system's regional settings
7/23/2007 5:23:24 PM - Startup - Loading Settings
7/23/2007 5:23:25 PM - Startup - Settings Loaded.
7/23/2007 5:23:25 PM - Startup - Loading configuration file ...
7/23/2007 5:23:25 PM - Info - Loading device types file...
7/23/2007 5:23:25 PM - Database - Opening up HomeSeer database C:\Program Files\HomeSeer 2\config\sample.mdb
7/23/2007 5:23:27 PM - Database - HomeSeer configuration database C:\Program Files\HomeSeer 2\config\sample.mdb has been closed.
7/23/2007 5:23:27 PM - Info - Loading Devices...
7/23/2007 5:23:27 PM - Load Config - 2 total devices loaded.
7/23/2007 5:23:27 PM - Load Config - Checking device type settings for all devices...
7/23/2007 5:23:27 PM - Load Config - Finished checking device type settings.
7/23/2007 5:23:28 PM - Load Config - Loading Events...
7/23/2007 5:23:28 PM - Load Config - 7 total events loaded.
7/23/2007 5:23:28 PM - Info - Loading TV Timers...
7/23/2007 5:23:28 PM - Info - HomeSeer version is: 2.2.0.11
7/23/2007 5:23:28 PM - Info - Initializing phone interface...
7/23/2007 5:23:28 PM - Warning - No addressbook.xml file exists, creating default
7/23/2007 5:23:28 PM - Warning - No mailboxes.xml file exists, creating default
7/23/2007 5:23:28 PM - HSPhone - HomeSeer Phone Web Interface initializing.
7/23/2007 5:23:28 PM - Updater - Starting installation of updates
7/23/2007 5:23:28 PM - Updater - Applying update: mcsSprinklersB
7/23/2007 5:23:33 PM - Updater - Executing installer: C:\Program Files\HomeSeer 2\updates2\mcsSprinklersB2.7.0.291\setup_hs.exe
7/23/2007 5:24:54 PM - Updater - Copying file: C:\Program Files\HomeSeer 2\hspi_mcsSprinklersb.ocx
7/23/2007 5:24:54 PM - Info - Registering C:\Program Files\HomeSeer 2\hspi_mcsSprinklersb.ocx with Windows
7/23/2007 5:24:56 PM - Updater - Copying file: C:\Program Files\HomeSeer 2\Config\mcsSprinklersb.lf
7/23/2007 5:24:56 PM - Updater - Installation of updates completed
7/23/2007 5:24:56 PM - Startup - Checking for available plug-ins
7/23/2007 5:24:57 PM - Info - Found plug-in: Maestro Sprinklers, version: 2.5.0.0
7/23/2007 5:24:57 PM - Info - Found plug-in: mcsSprinklersB, version: 2.7.0.291
7/23/2007 5:24:57 PM - Startup - Restoring device status
7/23/2007 5:24:57 PM - Startup - Initializing Plug-Ins
7/23/2007 5:24:57 PM - Info - Finished initializing X10 interface
7/23/2007 5:24:57 PM - Info - Finished initializing infrared interface
7/23/2007 5:24:57 PM - Info - Initializing Plug-in: Maestro Sprinklers
7/23/2007 5:24:57 PM - Info - Finished initializing plug-in Maestro Sprinklers
7/23/2007 5:24:59 PM - Info - Local IP address is: 192.168.0.101/24
7/23/2007 5:24:59 PM - Info - Web server remote access is disabled. It can only be accessed from this computer
7/23/2007 5:24:59 PM - Info - Web Server started on localhost, port 80
7/23/2007 5:25:00 PM - Info - Web Server authorized local login successful from: 127.0.0.1 User: default
7/23/2007 5:25:00 PM - Info - Creating ASP.NET application host...
7/23/2007 5:25:10 PM - Info - ASP.NET application host created
7/23/2007 5:25:10 PM - Startup - Initializing text to speech
7/23/2007 5:25:10 PM - Info - Listening for remote speaker connections on port 8742
7/23/2007 5:25:10 PM - Startup - Start remoting
7/23/2007 5:25:10 PM - Startup - Start event processing
7/23/2007 5:25:10 PM - Info - This version of HomeSeer is registered.
7/23/2007 5:25:10 PM - Startup - Scripting is OK
7/23/2007 5:25:11 PM - Info - Finished initializing scripting
7/23/2007 5:25:11 PM - Startup - Starting scheduler
7/23/2007 5:25:11 PM - Startup - Start up complete.
7/23/2007 5:25:14 PM - Info - Speaker client connected from: 127.0.0.1
7/23/2007 5:25:16 PM - Info - Speaker host added, Name: PROWIRE IP address: 127.0.0.1
7/23/2007 5:25:38 PM - Info - Interface mcsSprinklersB is running as a trial, 29 days remaining.
7/23/2007 5:25:38 PM - Info - Initializing Plug-in: mcsSprinklersB
7/23/2007 5:25:38 PM - mcsSprinklers - Basic License Recognized
7/23/2007 5:25:38 PM - COM Plugin - Calling InitIO
7/23/2007 5:25:38 PM - Info - Finished initializing plug-in mcsSprinklersB
7/23/2007 5:25:43 PM - ConfigIO - Calling ConfigIO for mcsSprinklersB
7/23/2007 5:25:49 PM - ConfigIO - Calling ConfigIO for mcsSprinklersB
7/23/2007 5:26:23 PM - ConfigIO - Calling ConfigIO for mcsSprinklersB
From a browser put the URL
http://localhost:xxxx/mcsSprinklers/...sp?Page=Status
where xxxx is the server port you setup for Homeseer.
joewire
tried the link
Script Error:
File not found: C:\Program Files\HomeSeer 2\html\mcsSprinklers/mcsSprinklers.asp
When the line in the log
was executed it prompted you for an install location. It appears the intall location is not Homeseer 2 folder. When Homeseer is not running use control panel add/remove programs to remove mcsSprinklers and then run the file
C:\Program Files\HomeSeer 2\updates2\mcsSprinklersB2.7.0.291\setup_hs.exe again and assure that the install path is C:\Program Files\HomeSeer 2
joewire
not able to config
ok i re installed the program . i now have "mcssprinklers" and also "mcssprinklers B" but under the mcssprinklers tab once enabled there is no cinfig button . i tried the config under the mcssprinklers B tab but nothing happened . and further ideas?
thank you
Joe D
joewire
still no go on
here is the link im putting into my browser http://localhost:80/mcsSprinklers/mc...sp?Page=Status. still no go
joewire
yes the .asp is in the path, by the path are you talking about in the link in pu in the address bar .i dont have any MCS icons or tabs anywhere execept for the interfaces page .
Are you trying to install it from a remote computer? If you are on the local computer you should have the HS menu above the HS log and it will contain the link to mcsSprinklers. Look at the bottom of post #5 at http://board.homeseer.com/showthread.php?t=122406 to see the menu item I'm referencing.
Your earlier message showed:
File not found: C:\Program Files\HomeSeer 2\html\mcsSprinklers\mcsSprinklers.asp
Is that file present? It is the one that is called when you put http://localhost:80/mcsSprinklers/mc...sp?Page=Status
in the browser URL address
joewire
yes i am on the local computer that HS is installed on . the .asp file is the and its file size is 487kb. as far as seeing any reference to MCS like i said be fore there is only a tab on the interface page. i dont see any items specific to MCS on top menu in the HS log . am i going to have to install a standalone version? if so i have already tried that and it will not let me run on trial , the trial part is grayed out . i have tried downloading the software 4 time from 2 seperate locations ( home and work )
If you have installed the standalone on the same computer and not in the Homeseer 2 folder then you likely have a problem with the registry. The trial is grayed out because you likely have deleted the \Config\mcsSprinklers_License.ini so the record of when the trial started has been lost and it will not let you trail with an unknown expiration. I posted http://mcsSprinklers.com/ResetmcsSprinklersTrial.exe that will reset you trial period for the standalone.
If you get an error from Homeseer that says that the mcsSprinklers.asp file is not present when accessed from a browser then there is something wrong with the paths where that file is located if you say it does exist.
If you installed the standalone then it is best to uninstall it from Control Panel / Add Remove Programs and then reinstall the plugin from the updater with care to put it in the Program Files\Homeseer 2 folder. Assure that no \config\mcsSprinkers_License.ini is present in the Homeser 2\Config folder if you want to user the standard HST method of licensing/trialing.
