Hello,
I've recently transitioned over to the VWS plugin and I've been getting the following error messages:
6/16/2008 11:55:40 AM VWS Error Exception error in ProcessDBaseData()-->Fields: System.IndexOutOfRangeException: Index was outside the bounds of the array. at HSPI_VWS.HSPI.ProcessDBaseData()
6/16/2008 11:55:40 AM VWS Info Data is older than 15 minutes, Check VWS
6/16/2008 11:55:45 AM VWS Info Data is older than 15 minutes, Check VWS
6/16/2008 11:55:50 AM VWS Info Data is older than 15 minutes, Check VWS
6/16/2008 11:55:55 AM VWS Info Data is older than 15 minutes, Check VWS
6/16/2008 11:56:01 AM VWS Info Data is older than 15 minutes, Check VWS
6/16/2008 11:56:06 AM VWS Info Data is older than 15 minutes, Check VWS
6/16/2008 11:56:11 AM VWS Info Data is older than 15 minutes, Check VWS
However, all of my virtual devices seem to be updated with the current data and I've looked at the Data.csv file and it's being updated every five minuts.
Is there something I'm not doing right?
Thanks.
Thanks.
