Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > HiTec Homes Plug-Ins > VWS
VWS Discussion area for the VWS (Virtual Weather Station) plug-in by Hi-Tec Home
Old December 4th, 2008, 10:32 PM
upstatemike's Avatar
upstatemike upstatemike is offline
Trouble Creating Devices
I just downloaded the VWS plugin and I am having trouble creating the devices. The device name "Weather Advisory" gets created twice (devics 2 and 3) and this makes all the rest of the names one device off from their corresponding values. I deleted all of the devices and created them over again but get the same result. What am I doing wrong?
***EDIT***
OK I manually changed all the device names so they line up correctly now. I am planning to use a script to put weather station values into stargate using something like this:
sub main()
hs.setDeviceValueByName("JDS vwsgust"),hs.DeviceValueByName("Wx Station wind gust")
end sub
I assme this will have issues because of the spaces in the weather station names? Do I need to change "Wx Station" to "VWS" and remove the spaces in the device names?
Old December 5th, 2008, 03:25 PM
It looks like the correct way to use weather station data with Stargate variables is:
sub main()
hs.setDeviceValueByName("JDS vwsgust"),hs.DeviceValueByName("VWS windgust")/100
end sub
Is this pretty much how other folks are doing it?
Old December 7th, 2008, 01:56 PM
I changed the location names and edited all the device names and everything is working great. My Stargate is now speaking the weather values and warning me when the winds get too high etc.
Thanks to all who responded to this thread with their helpful advice and support.
Old December 7th, 2008, 03:47 PM
Rupp's Avatar
Rupp Rupp is offline
Must not be many Stargate users left.
-Rupp
Old December 27th, 2008, 12:54 AM
scott12v scott12v is offline
I have the same issue with a Davis Weather Station. I wonder if the latest update caused the problem?
I have an old install that works with no issues.
Old December 27th, 2008, 10:57 AM
lpitman's Avatar
lpitman lpitman is offline
I will check out the code, even though I don't believe, that portion of the code has changed in over a year. Maybe some new re-action to HS?
-Larry
A member of "The HA Pioneer Group", MyWebSite
WHS 2011 Server - SageTV, HS 2.2.29 with 9TB Shared Hard Disk.
Plugins:
Ocelot, MitsubishiTV, DenonAVR, DirecTV, DVDMovies, HAI-Thermostat, HAI, Hauppauge, lrpSpeak, MediaPlayer, Rain8Net, Sprinklers, UIRT, VWS.
Hardware:
Intel 3.0Ghz CPU with 12Gb. Ram and 2Tb SATA HD. Davis Inst. VantagePro II, AB8SS, Rain8Net, RC80 Thermostat, OmniProII, Ocelot, X10, UPB, HD-200 Extenders.
Old December 27th, 2008, 11:16 AM
Thanks. When I said "latest update" I meant it could be the plugin, Homeseer, or even VWS.
Scott
Old May 30th, 2009, 12:33 AM
I just rebuilt my Hometroller and am trying to re-install the VWS and Stargate plugins but things aren't working like they did before.
1- The devices end up with overlapping house codes so I get VWS data loaded into Stargate devices.
2- When I delete unwanted devices from the VWS plugin device list, they are put back next time I start Homeseer.
3- The scripts I use to load VWS data into Stargate no longer work, such as:
sub main()
hs.setDeviceValueByName("JDS vwshumid"),hs.DeviceValueByName("VWS Outsidehumidity")/100
end sub
Is there a way to manually choose the House Code for the VWS plugin to use and to delete devices I don't want such that they stay deleted? Is my script breaking because of the house code overlap or some other reason?
Old June 4th, 2009, 03:33 PM
lpitman's Avatar
Make sure you are using the latest build from the updater...
Old June 4th, 2009, 08:54 PM
Yes it is the latest version. After several iterations of deleting devices, disabling plugins, and restarting them in a specific order, I was able to solve the House-Code overlap. I then manually changed the room name from WX Station to VWS to get rid of the space and that solved my script syntax problems. (I also edited out any spaces in device names).
Old June 5th, 2009, 04:58 PM
lpitman's Avatar
Please note from the Web-based help file that you can save these new names in the INI file...this would benefit you in any future restore...etc...
HTML code is On
