Here is my question. When I have a Keypadlinc button programmed for example Button B, if I push it on, I set up an event that should update the status on my Homeseer system:
Trigger Tab:
Trigger: Insteon Special Triggers
Select insteon Device: Insteon Master bedroom Keypad Button B
When the Selected Device Does the Following: Transmits an On Command
Action Tab:
Insteon Master Bedroom Keypad-Button B On
Insteon Virtual Master Bedroom-Keypad Button B On (Z4)
Now when I push Button B on the Master Bedroom Keypad, I can see in the log only the Insteon communication:
9/19/2009 2:36:33 AM - Insteon - PLM_ProcessInBuffer received STX 0x50 (Raw Insteon Rec):01 0D C6 ED 0F D4 EF 41 13 04 - Event: New msg for PLC , Src[0D.C6.ED] Dst[0F.D4.EF] {Grp Cln} Cmd:Go OFF Ex: 04
But it won't run the event or update the device status. So the PLM must be working if it is seeing the button being pressed.
I had this event working a couple of days ago, but now it doesn't seem to work. I have tried this on multiple keypadlincs and I have received the same results.
Any suggestions?
Trigger Tab:
Action Tab:
Any suggestions?
