I moved from HSPRO 2.5.0.5 and vhs ver 14.01 internet addition on an old Pentium 4 to a new Hometroller series 3 with the same software. It has been working fine for years.
The VWS software is loaded same as before in the c:vws directory and the csv files under c:\vws\data directory.
I am getting the following error in the HS log:
1/7/2011 2:00:40 PM - VWS Error - Could not read the CSV file after three attempts: C:\vws\data\data.csv
Uer the c:\vws\data directory I have the following csv files, data.csv 1KB, dbase.csv 53KB and data2.csv 1KB. They are updated pretty often.
The VWS.ini is as follows:
[Config]
CSVPath=C:\vws\data
DBasePath=C:\VWS\data
UseWarning=False
WarningPath=C:\Program Files\HomeSeer HSPRO\Data\VWS\
SpeakWarning=False
PreSpeakString=
NumTimeToWarn=2
MinBetweenWarn=15
MorningBeginWarnTime=7
NightEndWarnTime=10
Metric=False
ScaleValues=True
PollInterval=5
ReadCSVFile=True
DBPollInterval=1
ReadDBFile=False
Debug=False
[ZoneNames]
Zone1=VWS Data Status
Zone2=Weather Advisory
Zone3=Wind Speed
Zone4=Wind Gust
Zone5=Wind Direction
Zone6=Inside Humidity
Zone7=Outside Humidity
Zone8=Inside Temp
Zone9=Outside Temp
Zone10=Barometer
Zone11=Total Rain
Zone12=Daily Rain
Zone13=Hourly Rain
Zone14=Weather Conditions
Zone15=Channel 1 Temp
Zone16=Channel 1 Humidity
Zone17=Channel 2 Temp
Zone18=Channel 2 Humidity
Zone19=Channel 3 Temp
Zone20=Channel 3 Humidity
Zone21=Evapo Transpiration
Zone22=UV Index
Zone23=Solar Radiation
Zone24=Wind Chill
Zone25=Inside Heat Index
Zone26=Outside Heat Index
Zone27=Dew Point
Zone28=Rain Rate
Zone29=Outside Temp Rate
Zone30=Inside Temp Rate
Zone31=Barometer Rate
Zone32=Channel 1 Temp Rate
Zone33=Channel 2 Temp Rate
Zone34=Channel 3 Temp Rate
Zone35=High Temp
Zone36=Low Temp
Zone37=Monthly Rain
Zone38=Yearly Rain
[Values]
DailyStatsDay= 7
DailyStatsMonth= 1
DailyHighTemp= 70
DailyLowTemp= 0
Any idea's would be appreciated.
[Config]
CSVPath=C:\vws\data
UseWarning=False
SpeakWarning=False
PreSpeakString=
NumTimeToWarn=2
MinBetweenWarn=15
NightEndWarnTime=10
Metric=False
ScaleValues=True
PollInterval=5
ReadCSVFile=True
DBPollInterval=1
ReadDBFile=False
Debug=False
[ZoneNames]
Zone3=Wind Speed
Zone4=Wind Gust
Zone8=Inside Temp
Zone9=Outside Temp
Zone10=Barometer
Zone11=Total Rain
Zone12=Daily Rain
Zone13=Hourly Rain
Zone22=UV Index
Zone24=Wind Chill
Zone27=Dew Point
Zone28=Rain Rate
Zone35=High Temp
Zone36=Low Temp
Zone37=Monthly Rain
Zone38=Yearly Rain
[Values]
DailyStatsDay= 7
DailyStatsMonth= 1
DailyHighTemp= 70
DailyLowTemp= 0
