Version 1.7.0.0 Beta (Released 2/19/2012)
The attached version includes some significant code changes in preparation for some new Smarthome devices. KPL support has also been modified and improved significantly. The new Trigger Group (see below) feature may also affect the results of your Events; you will need to test events that control KPL buttons directly if you enable the Trigger Group on a KPL button.
As always, please provide as much feedback and log snippets when posting issues.
New Features
- Trigger Group feature for KPLs. The HS status page on/off buttons can now trigger the devices linked to KPL btns. Change the KPL buttons on the Device Edit page: set an individual button to Trigger Group mode and save the changes. (for i2 devices)
- HS status page On buttons will now use the default on level programmed into the switch.
- Added hover help text to KPL Edit Device page
- Added Make Device Beep action (for i2 devices)
Revisions
- Revised how the KPL settings are retrieved -- much faster now. (for i2 devices)
- Swap Interface routine now includes RF only devices. You will be prompted to put the RF only device into Linking mode before the routine continues.
- Better error trapping and restarting if the virtual serial port crashes or if the USB cable is disconnected and reconnected. Update your FTDI Drivers.
- Cosmetic changes to the Manage Device page and Device Insteon Edit page to improve navigation. Requires IE 8 or later to see images.
Fixes
- Hop count was computed incorrectly if less than 4 Hops is selected on Config page.
- RemoteLinc issue
- Fanlinc light off issue
- Group controller missing after device swapped; now updated to new device
- Syncing KPL devices on the HS status page
- Status message display during programming routines.
New Devices Supported
- Smarthome is shipping devices with their new Insteon protocol called i2CS. When you register one of these devices the protocol will show as i2CS.
To Install:
1. Backup your current hs database and insteon.ini
2. Shutdown HS
3. Copy the hspi_insteon.dll to the homeseer folder
4. For new users only: copy the insteon.lf to the homeseer\config (this will provide a 30-day trial license)
Licenses are available in the HST store:
http://store.homeseer.com/store/MNSa...n-P948C94.aspx
Enjoy!
New Features
Revisions
Fixes
- RemoteLinc issue
To Install:
2. Shutdown HS
Enjoy!
