Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > HiTec Homes Plug-Ins > VWS
VWS Discussion area for the VWS (Virtual Weather Station) plug-in by Hi-Tec Home
Old February 25th, 2013, 07:07 PM
Wavemagic Wavemagic is offline
Question Index outside of bounds of the array error for VWS
I am running HSPRO (V2.5.0.79) and have the VWS Plug-In (V2.2.0.32) connected to my VWS weather station.
I am getting lots of "In SetDevSting, hc=1 dc=str=%/hr: Index was outside the bounds of the array" errors. The results in STATUS of Homeseer appear OK. How do I get rid of all the errors. A screen shot is attached.
Old February 25th, 2013, 07:41 PM
Rupp's Avatar
Rupp Rupp is offline
Look one post below yours for a post with the same error.
-Rupp
Old February 25th, 2013, 09:13 PM
Thanks for pointing that out to me. I guess I should have read the others first. After reading the string in the post below mine, I am not sure a definitive answer was found. Did I miss something?
Old February 25th, 2013, 09:24 PM
Rupp's Avatar
It appears the plugin author doesn't know the fix but the message shouldn't cause an issue other than filling up your log files. This message was added to HS a few versions ago to try and located some memory leak issues.
Old February 25th, 2013, 09:26 PM
I think you are correct! All appears to work fine, except for my log getting filled up with annoying RED error messages. Should I just leave all alone for now and maybe someone will find an answer soon or trash the plug-in?
Old February 25th, 2013, 09:33 PM
Rupp's Avatar
Yes, let it be and hopefully the plugin author will find the cause to this issue. Again, it's not really the plugin authors fault as the check was recently added to HS and it may take a bit of time to find the issue.
Old February 25th, 2013, 09:34 PM
Thanks for the great and fast reply. I will wait and be patient. Thanks for all your help.
Old February 26th, 2013, 01:18 PM
Rupp's Avatar
This has been fixed.
http://board.homeseer.com/showthread.php?t=157569
Old February 26th, 2013, 01:50 PM
lpitman's Avatar
lpitman lpitman is offline
Sorry I didn't wait long enough in my testing, the errors are still showing up, guess I'll keep looking.
-Larry
A member of "The HA Pioneer Group", MyWebSite
WHS 2011 Server - SageTV, HS 2.2.29 with 9TB Shared Hard Disk.
Plugins:
Ocelot, MitsubishiTV, DenonAVR, DirecTV, DVDMovies, HAI-Thermostat, HAI, Hauppauge, lrpSpeak, MediaPlayer, Rain8Net, Sprinklers, UIRT, VWS.
Hardware:
Intel 3.0Ghz CPU with 12Gb. Ram and 2Tb SATA HD. Davis Inst. VantagePro II, AB8SS, Rain8Net, RC80 Thermostat, OmniProII, Ocelot, X10, UPB, HD-200 Extenders.
Tags
out of bounds
HTML code is On
