It's definitely now requiring commands to be repeated multiple times. I didn't really have any issues with the last version but this latest is.
Kinect Plug-in - Beta Testing
Seems that the reliability has some issues in the latest builds I am running 3.0.0.18 with not much luck how can I go back to a previous version of the plugin. it was really stable before the echo cancellation was added that is where I started to see issues I have tried to disable the echo cancellation and it still dosent hear me most times any ideas
Cheers KenHSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Originally posted by kenrad View PostSeems that the reliability has some issues in the latest builds I am running 3.0.0.18 with not much luck how can I go back to a previous version of the plugin. it was really stable before the echo cancellation was added that is where I started to see issues I have tried to disable the echo cancellation and it still dosent hear me most times any ideas
Cheers Ken
have you restarted the plugin after disabling echo cancellation?
The updater still has version 3.0.0.14 so you can go back to this previous version, but I would really appreciate it if you could help me investigate what's wrong.
Please send me your ini file, also could you try to enable developer mode and set log level to Trace, to see what the Kinect is hearing when you say some commands. Thanks
Ok spud,
I think I got it. Im thinking that restarting the plugin didnt do it a complete reboot of the hs machine and all is running good with 3.0.0.18
Does this work for remote instances yet?HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Originally posted by kenrad View PostDoes this work for remote instances yet?
Rich said he would have a look at it last week, I have no news since then.
HI Spud,
I am having problems getting the plugin to work and wandered if you can point me in the correct direction.
I have installed V3.0.0.18 and the SDK, runtime and Drivers V1.7.
When I start the plugin I get the following error and the kinect will not function:
Aug-27 19:28:13 Kinect INFO Kinect initialized
Aug-27 19:28:13 Kinect ERROR Method not found: 'Void Kinect.Toolbox.GestureDetector.add_OnGestureDetected(System. Action`2)'.
Aug-27 19:28:11 Kinect INFO Kinect version 3.0.0.18
Aug-27 19:28:10 Info Plugin Kinect has connected. IP:127.0.0.1:55799
The plugin sees the kinect and when I turn on debugging I get nothing in the log.
Any Ideas on how to fix it?
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Greig.
In bin/Kinect make sure you have the dll from the 3.0.0.18 zip
and delete Kinect.Toolbox.dll from the HS3 root dir if you have one there
I had an old Kinect.Toolbox.dll in the HS3 root dir so I removed it and it is now working.
Scripts = Various
Originally posted by pabbott@cpak.com View PostDoes the plugin support the kinect 2? Future plans for this?
Philip
Also, the kinect for Xbox One can't be plugged to a PC (unlike the kinect for XBox 360), so only the kinect for windows v2 will work, and it will need windows 8.
Originally posted by kideon View PostDoing any more development on this plugin in general?
But yes I will continue to develop this plugin depending on the demand for new features.
Finally got the power adapter so I could try out the 360 Kinect instead of the v2 for Windows which I got a refund on. Running 3.0.0.18.
I'm seeing this error in the log when set to trace and starting the Kinect plugin:
Oct-05 3:55:10 PM Plug-In Finished initializing plug-in Kinect
Oct-05 3:55:10 PM Kinect DEBUG End Init
Oct-05 3:55:10 PM Kinect DEBUG Web Pages Registered
Oct-05 3:55:10 PM Kinect DEBUG Visual Recognition Initialized
Oct-05 3:55:10 PM Kinect DEBUG Voice Recognition Initialized
Oct-05 3:55:10 PM Kinect DEBUG USB\VID_0409&PID_005A\5&1F74503E&0&1 status=DeviceNotSupported
Oct-05 3:55:10 PM Kinect INFO Kinect version 3.0.0.18
Oct-05 3:55:10 PM Kinect DEBUG Logger Initialized
The Kinect says Model 1414 on the bottom of. Everything looks correct in device manager - under Kinect for Windows I have 4 devices Audio Array Control/Camera/Device/Security control, and a Kinect USB Audio under the Sound node.
Running the 1.7 SDK/Runtime.
On the general tab of the PI settings, the top dropdown for Kinect Sensor is empty, so that's why I suspected something was not right as I could seem to get it to do anything when playing with some events.
Any ideas much appreciated
John.
