This is the first HS3 Release which has all the functionality available in HS2. You will get a 30 day trial before a license is required. You may purchase a license from the HS Store at the following link:
http://store.homeseer.com/store/MNSa...P1738C282.aspx
Known Issues
- This is not Linux compatible or tested.
- No plugin specific Conditions. Use HS device conditions which will provide the same functionality.
- The Firmware Uploader is still experimental here. use the nutech.com tools for now.
Fixes:
- "Do not log messages" Option for RF Devices (3.0.0.9)
- partition status change fires device value trigger (3.0.0.10)
Notes and Comments:
1. You must start from scratch. Nothing will be transferred from your HS2 setup.
2. Please reply to this thread with all comments and errors. I need repeatable steps so i can duplicate the error in order to fix it.
To Install:
1. Shutdown HS3
2. Extract the zip contents to the Homeseer 3 folder.
The contents should end up in their respective folders. HSPI_VistaAlarm.exe and FTD2XX.dll in the homeseer 3 folder, and everything else in the proper html subfolder based on the Path in the zip folder.
4. Restart HS3 and goto to the Manage Plugin page
5. Enable the plugin and set the Com Port to your AD2USB port
6. Restart HS3 again if necessary
7. You will need to enable the Monitor (address Vista 1) to get things rolling.
Setup:
1. Once the plugin is running it will create 6 new devices. You can always delete them and restart HS3 to have them recreated.
2. Configure your Partitions as before. You need to know the panel address typically 16 for a 20p. Check your panel programming if you are unsure.
3. Add your zones and RF devices as necessary
4. Test and report back to this thread
If you enabled Developer Mode on the Plugin Manage page, you will get a command window that will display the AD2USB messages. this might help with debugging or at least let you know the plugin is seeing panel msgs.
Known Issues
Fixes:
Notes and Comments:
To Install:
1. Shutdown HS3
Setup:
