Spud --
This is very timely as another customer recently asked about the TH1300RF for which we recently purchased your plug-in:
Our bathroom floor has finally set and we starting testing the Sinope TH1300RF today with your plug-in. We ran into an issue we HOPE you can fix: The TH1300RF has BOTH Ambient and Floor temperature sensors and has a local setup option to display and use either Floor or Ambient. We have that option set to Floor since we have underfloor heat. Your Plug-in is only reporting Ambient room temperature and does not provide the FLOOR temperature which is critical (see pictures enclosed). I assume Sinope's API was modified at some point to add reading both temperatures for their underfloor thermostats and we hope you can fix this. If possible it would be great to have BOTH Floor and Ambient available for HS3 scripting.
If you need debug information or access to our neviweb.com account please let me know.
