I'm considering changing my home audio. This is what I have
Three sets of speakers (kitchen, bathroom, patio). All wired to a central location.
I want to be able to control them via an app or physically.
I also want to be able to stream Amazon and local radio stations (via TuneIn or an actual tuner).
Initially I wanted to be able to play different music in each zone. Now I think I could drop that requirement. Just being able to control volume in each zone independently would be good enough.
Current solution
Three amps
Three bose soundTouch wireless links
BoseSoundTouch plug-in for HS3
Three HS dimmers
Three HS switches
HS events to sync the dimmers to the volume for each zone.
HS events to change to certain Bose preset based on single, double or hold of switches.
This worked OK. Until the plug-in started acting up. It is a little slow to respond even when it was working correctly.
I'm going to try reinstalling the plug-in. But if that doesn't end up working I think I'm going to look for a more reliable solution.
Any ideas on what I might do?
Current solution
Three amps
Three HS dimmers
Three HS switches
