OmniPlugin V.26 System Variables
    Here disabled plugin first and removed all system variables then re enabled plugin and let the Omni plugin recreate all of the variables.
    Note here using central services with a primary copper phone line. Putting it in test mode with CO when testing.
    Going slower here testing as well as I can test here...so baby steps here...
    [ATTACH]67694[/ATTACH]
    • Battery - showed voltage of 13.XX here for a bit - picked up the phone and went to zero and stayed there.
    • Freeze
    • ac
    • phone - never changes with phone line dead trouble
    • communicator
    • codes
    • bell
    • fuse
    • dcm - alway shows at fault
    • connection
    - disconnected phone at RJ11 - no dialtone on phone as expected - Omni Panel Phone LED lamp on - Phone line dead trouble on keypad, no changes in system status above for phone, communicator and DCM. Note: there have been no changes in system variables (except for battery going to zero) since around 9:20 / 9:36 AM this morning.
