Originally posted by tahl
View Post
KMS says no stopped K or M even though it's not true
Originally posted by spud View PostYou shouldn't have the remote instance "green". Turned it off as well. It should say "Loaded Remotely" instead. And this may be the cause of it quitting.
In meantime, I'm going to re-enable the remote instance in Managed Plug-ins but keep the HS instance (which I don't want to monitor) disabled.
Please advise.
Originally posted by tahl View PostWell, disabling it seems to have, well, disabled it. I.e., it's not working anymore. I've enclosed a screenshot. Just to be clear. In order to get KMS sensor to work, you have to disable it in Manage Plug-ins?
When you start the run.bat on your remote computer, it starts a plugin instance that talks directly to HS3, if then you enable the same instance name from the "Plug-ins > Manage" page it creates a local instance with the same name which will mess everything up.
So at this point, if I were you I would shut down all instances local and remote, then manually delete all KMS devices from the "Device Management" page. Then only start the run.bat on your remote computer.
Here is a screenshot of what you should see:
Originally posted by spud View PostI see how it can be confusing but yes you MUST leave it disable in "Plug-ins > Manage" page.
[ATTACH]64761[/ATTACH]
What's next?
Originally posted by tahl View PostStill having problems. I followed your new instructions to the T. The remote computer has just one process for the remote KMS running. The HS has no KMS process running. The Manage Plug-ins looks just like your screenshot. And still, the remote's KMS process just randomly, quietly quits. It usually around a couple of days. See attached screenshot. I discovered it died last night and just re-ran it. Also, note on the title bar that it's running as admin.
What's next?
Could you check the Windows Event Viewer and see if there is any error/warning related to HSPI_KMS.exe?
Originally posted by spud View PostI don't know what could make it quit silently like that.
Under what conditions can it normally exit? Maybe it is taking that rather than dying. Otherwise, what are next steps?
Originally posted by tahl View PostChecked the logs. There are no application, security or system events around that time. No anti-virus actions.
However in both cases, we would see something printed to the console, that's why it's very strange.
In version 3.0.0.6, I have added some more code to trap unhandled exceptions, so please install and test this version.
https://forums.homeseer.com/showthread.php?t=172552
