Old February 12th, 2018, 03:41 PM
digidoc digidoc is offline
Seer Deluxe
HS3 license from Hometroller to PC
I have a Hometroller with HS3 running on Win XP Embedded. With internet security having changed over the years and no upgrade path for XP, I'm going to have to move to a newer OS. Will I be able to transfer my Hometroller license to another computer?
Old February 12th, 2018, 05:03 PM
Rupp's Avatar
Rupp Rupp is offline
OverSeer
Yes you can move that license to a PC. It may require a reset and if it does email support@homeseer.com to reset your license.
-Rupp
Old February 12th, 2018, 05:22 PM
Seer Deluxe
Thanks for the quick reply. New PC ordered and on its way.
Old February 12th, 2018, 07:39 PM
integlikewhoa integlikewhoa is offline
Seer Master
Quote:
I would assume you could, but the way I was told is you can't. And the reason for that was they didn't want anyone saleing off a Hometroller without a license. So when I started with HS3 I was always told to buy your own hardware so you could bounce from linux to windows and to any hardware you wanted. If you bought a package it was tied to that package and couldn't be split up and sold as hardware with no license or license with no hardware.
But I would have to assume if you called them and pled your case that your hardware has died and you want to move to new hardware it should be possible.
In any case I would like to hear from HS what the actual rules are again.
JIM
Old February 12th, 2018, 09:25 PM
Rupp's Avatar
OverSeer
You can use the license on a new PC but that will prevent selling the hardware with a license. If you sell it the new user will have to purchase a license to use on the hardware.
Old February 13th, 2018, 01:40 AM
Seer Master
Please read what you have said in the past. specifically reply #5 and what you quoted from the other user.
https://forums.homeseer.com/showthread.php?t=184573
Old February 13th, 2018, 10:36 AM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
OverSeer
Rupp - I'd really recommend talking to mark or rich to make sure. Separating a hometroller license from the hardware is not going to be a good idea. In their licensing server, it will always show up as a hometroller license.
64 Z-Wave Nodes, 162 Events, 293 Devices
Old February 13th, 2018, 02:20 PM
Seer Deluxe
Post
Well, it seems that I stirred up a mess here. Maybe I should ask for a new operating system for my Hometroller to replace Windosw XP embedded, that is old, outdated, and no longer secure. While no one can future proof a product, and the hardware it runs on, this thing is not cheap and should not be considered disposable. I hope this ends well when the new box arrives and I try to load everything from the Hometroller.
Maybe the Hometroller license can be marked void in the database and a regular license can be issued for my new HS3 server.....???
Old February 13th, 2018, 02:52 PM
Pete's Avatar
Pete Pete is offline
OverSeer
Here helped a Hometroller user redo his old HS2 stuff and left the XPe in place and updated the OS drive. He sold it here with HS2 / license on it.
Many HS2 Hometroller folks have done this going to Homeseer 3.
He did not get very much for it...thinking around $100 or so.
As Rob mentions above you should keep both the hardware and software together.
BTW here still running XPe on my tabletop touchscreens (15). They work great and XPe is lighter than W7e or W8e. They do not talk to the internet so I am not worried.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.435
HTML code is Off
Can I use my HomeTroller-SEL-PRO License in Windows Environment? Stevemeck HS3 / HS3PRO Discussion 4 April 8th, 2017 04:28 PM
HomeTroller-ZeeS2 (MONO 3.x) vs. HomeTroller-ZeeS2V2 (MONO 4.x) – Z-Wave Action Issue mstukel HS3-Pi Discussion 9 October 21st, 2016 03:41 PM
HomeTroller-SEL license theclueless HS3 / HS3PRO Discussion 2 April 23rd, 2016 10:26 PM
Converting HomeTroller-SE to HomeTroller-SE PRO macromark How-To's 0 October 13th, 2011 04:20 PM
2nd license: License file gone. What do I do? Moskus HS2 / HSPRO 1 September 7th, 2010 09:56 AM
