Package Name: All-In-One Mobile Control Center (aka AIO)
Version: 1.0
Release Date: 10/25/2009
Author: Aaron Levey
Description:
This is made to be a quick all in one interface that is formatted to work on small
touchscreens like iPhone and Windows Mobile devices. It will work on nearly any browser
since most code is classic ASP and basic HTML/CSS
It is quick and simple to customize to your rooms and devices.
Disclaimer:
This package is NOT provided with any guarantee or warranty.
Use at your own risk... now have fun!
Package Requirements:
Homeseer 1.x or 2.0
Package Instruction:
Copy all package contents into the HTML folder in your HomeSeer installation directory.
Package Contents:
aio.asp
- use this in your browser)
aio.css
- style sheet for formatting, you can mod this if you want different formatting)
Images folder
- background and dimbar images plus other icons, you can change to any image or none - extra animated GIFs are included
webcontrols.asp
- Does all the dirty work. Don't mess with this unless you know what you are doing. If you make cool mods please share with the community
Usage:
Homeseer setup...
For each scene/event you want to control via the aio.asp, you must setup a Virtual or Status Only device. This device will store the status of the button to ensure it displays the proper state of the event/scene.
Editing the aio.asp...
You must edit the AIO.ASP for your devices and events
- All devices are called by 'Location' 'Device Name'
- ToggleCommandButton (Display Text on Button,Device in HS used for status,Event to trigger when button is Clicked ON,Event to trigger when button is Clicked OFF)
Known Issues:
-none-
Version: 1.0
Author: Aaron Levey
Description:
Disclaimer:
Homeseer 1.x or 2.0
Package Contents:
aio.asp
aio.css
Images folder
webcontrols.asp
Usage:
Homeseer setup...
Known Issues:
-none-
