Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help > How-To's
How-To's This area provides in-depth information on how to do something in HomeSeer or home automation.
Old October 13th, 2011, 04:20 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
HS Logo Converting HomeTroller-SE to HomeTroller-SE PRO
As with the other controllers, converting a HomeTroller-SE to an SE-PRO is fairly straightforward. However, there is one "gotcha"! The HSTouch Lite plug-in needs to be manually removed before HSTouch Server can replace it. Here are the steps.
  1. If you've note already done so, purchase the upgrade to HSRPO to get your new license codes.
  2. Disable HSProtect flash protection via the system tray icon and reboot the unit.
  3. Using the HomeTroller's Windows explorer, navigate to C:Program Files\HomeSeer HS2\ directory and delete hspi_HSTouch.dll. Now re-enable HSProtect flash protection and reboot the unit.
  4. After the reboot is complete, shut down HomeSeer, then navigate to www.homeseer.com/downloads, download the "HSPRO Updater" (about 4 mb) and run the updater.
  5. Once again, navigate to www.homeseer.com/downloads, download and install the HSTouch server plug-in
  6. Right-click on the HSProtect system tray icon and save your changes.
  7. Reboot the unit and access the license page on your HomeTroller to enter your new HSPRO license codes.
At this point, the upgrade should be complete and HSTouch should connect properly to the designer.
HTML code is On
