Jon00 DataScraper/JSON Parser Script For Homeseer 3 and Homeseer 4
    i restarted 5 x and still works , its temporary but it works , maybe rich now can see the problem
    HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
      hi jon ,
      i report back , its still working without any errors , and no lags .
      so it really fix the problem ,
      Kind regards
        //solved already
          hi jon ,
          is it possible to do more than 5 pattern ? its for my temperature readings , it need a lot more patterns.
          thanks in advance ,
          btw still running great and no lag or weird recurs
          Kind regards
            No but you can use multiple (.*?) entries in a single pattern and each will capture the data in the Jon00DataScraperdata.ini file. You can make up to 100 devices under a single 'Grab' configuration.
            Other than that you will have to use use additional 'Grab' definitions using the same source.
            Jon
              #21
              ok thanks ,
              but how to do that ?
              example:
              Pattern5=(?s) data-variable="humidity">.*?"wx-value">(.*?)</span>
              But how to put this line together with above one
              Pattern6=(?s) data-variable="visibility">.*?"wx-value">(.*?)</span>
              i only need a start on how to do that ,
              thanks for the quick reply
                #22
                It looks like the same HTML code repeated so you should only need to use a single pattern entry i.e.
                Pattern1=(?s) data-variable=.*?"wx-value">(.*?)</span>
                This should create several entries in the Jon00DataScraperData.ini file. You just need to determine which value is which.
                Jon
                  #23
                  aaa yes i see it , its really easy
                  im stupid , yeah ofcourse the html repeats , so if i do that a whole list will be listed in the data file
                  thanks jon again
                  kind regards
                    #24
                    ///EDIT Already found it out , hehe , i needed to add it to value also...
                    hi jon ,
                    i got a question , i was thinking about it but i really dont know how to do it ,
                    i use a scrape from windspeed it shows like (4.2) in the string
                    But is there a way to change the name of it ? so if it is in range of 4-5 it displays windpeed 3 as string..
                    like if it was a value i could change it in the status grapics ,
                    thanks in advance
                      #25
                      hi jon
                      Today i added 1 more number 14 to the scraper
                      and after that my cpu went 100% and the scraper doesnt work anymore , even if i put 14 away , it doesnt update anymore ....
                      there is no error or nothing in the log... but no devices are created or opdated
                      what to do now ?
                      this is what i had :
                      4+6+7+8+9+10+11+12+13+14
                        #26
                        I cannot see how that can happen. Did you restart HS?
                        Jon
                          #27
                          hi jon
                          yes i restarted multiple times , then i delete the devices in homeseer and only want to update nr 14 , he doesnt create devices ,
                          i also deleted the scraperdata and checked if its created , so i checked it and its created with all the data in it ... but no homeseer devices...
                          so i try again now and i get a hstouch warning and it has updated nr13 after a few times..
                          Aug-14 17:36:40	 	HSTouch Server Warning	Exception on Value Change callback: Object reference not set to an instance of an object.
                          Aug-14 17:36:40	 	Jon00_DataScrape	Virtual device created for Address Jon00-DS-013-5 with Reference: 1216
                          Aug-14 17:36:40	 	Jon00_DataScrape	Virtual device created for Address Jon00-DS-013-4 with Reference: 1215
                          Aug-14 17:36:40	 	Jon00_DataScrape	Virtual device created for Address Jon00-DS-013-3 with Reference: 1214
                          Aug-14 17:36:40	 	Jon00_DataScrape	Virtual device created for Address Jon00-DS-013-2 with Reference: 1213
                          Aug-14 17:36:40	 	Jon00_DataScrape	Virtual device created for Address Jon00-DS-013-1 with Reference: 1212
                          Aug-14 17:36:38	 	Event	Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/Jon00DataScraper.vben
                          Aug-14 17:36:38	 	Event	Event Trigger "test Jon Scraper t"
                            #28
                            Are you willing to post what you are scraping for no 14 and the pattern etc?
                            Jon
                              #29
                              yes ofcourse , it worked before and now i get 100%cpu with it and doesnt create anymore devices
                                #30
                                it woked before , it grabs ok , but doesnt create devices anymore....and i get 100%cpu
                                Path=http://dutch.wunderground.com/cgi-bin/findweather/getForecast?query=pws:ILIMBURG37
                                TextFile=1
                                Encoding=UTF-8
                                Username=
                                Password=
                                Options=
                                UserAgent=
                                Devicemode=0
                                Pattern1=(?s)<span class="wx-value">(.*?)</span>
                                Pattern2=(?s)<a href="/EU/NL/012.html#warn">	nederlands: (.*?)english: Risk of</a>
                                Pattern3=(?s).*? data-variable="humidity"><span class="wx-value">(.*?)</span>
                                DeviceName1=WeerRadar HS
                                DeviceText1=WeerRadar HS
                                DeviceValue1=
                                DeviceImage1=
                                Speakbutton1=1
                                TriggerString1=
                                SearchMode1=1
                                TriggerEvent1=
                                DeviceName2=Temp now
                                DeviceText2=[6]℃
                                DeviceValue2=
                                DeviceImage2=
                                Speakbutton2=1
                                TriggerString2=
                                SearchMode2=1
                                TriggerEvent2=
                                DeviceName3=Humidity
                                DeviceText3=[17]%
                                DeviceValue3=
                                DeviceImage3=
                                Speakbutton3=1
                                TriggerString3=
                                SearchMode3=1
                                TriggerEvent3=
                                DeviceName4=Windspeed
                                DeviceText4=[10]
                                DeviceValue4=[10]
                                DeviceImage4=
                                Speakbutton4=1
                                TriggerString4=
                                SearchMode4=1
                                TriggerEvent4=
                                DeviceName5=Winddirection
                                DeviceText5=[9]
                                DeviceValue5=
                                DeviceImage5=
                                Speakbutton5=1
                                TriggerString5=
                                SearchMode5=1
                                TriggerEvent5=
                                DeviceName6=Pressure
                                DeviceText6=[11] hPa
                                DeviceValue6=
                                DeviceImage6=
                                Speakbutton6=1
                                TriggerString6=
                                SearchMode6=1
                                TriggerEvent6=
                                DeviceName7=UV
                                DeviceText7=N.A van de 12
                                DeviceValue7=
                                DeviceImage7=
                                Speakbutton7=1
                                TriggerString7=
                                SearchMode7=1
                                TriggerEvent7=
                                DeviceName8=Voelt als
                                DeviceText8=[7]℃
                                DeviceValue8=
                                DeviceImage8=
                                Speakbutton8=1
                                TriggerString8=
                                SearchMode8=1
                                TriggerEvent8=
                                DeviceName9=Clouds
                                DeviceText9=[5]
                                DeviceValue9=
                                DeviceImage9=
                                Speakbutton9=1
                                TriggerString9=
                                SearchMode9=1
                                TriggerEvent9=
                                DeviceName10=Zicht
                                DeviceText10=[12]km
                                DeviceValue10=
                                DeviceImage10=
                                Speakbutton10=1
                                TriggerString10=
                                SearchMode10=1
                                TriggerEvent10=
                                DeviceName11=Warning Message
                                DeviceText11=[100]
                                DeviceValue11=
                                DeviceImage11=
                                Speakbutton11=1
                                TriggerString11=
                                SearchMode11=1
                                TriggerEvent11=
