yes it gets populated perfectly
i can you send the link in a pm if u want.
<!DOCTYPE html> <html lang="en" ng-app="patiobarApp"> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=edge"> <meta name="viewport" content="width=device-width, user-scalable=no"> <title>Patiobar</title> <link rel="stylesheet" href="/css/bootstrap.min.css"> <link rel="stylesheet" href="/css/main.css"> </head> <body> <nav class="navbar navbar-inverse" role="navigation" ng-controller="StationController"> <div class="container-fluid"> <div class="navbar-header"> <button type="button" class="navbar-toggle" data-toggle="collapse" data-target="#stations"> <span class="sr-only">Toggle Stations</span> <span class="icon-bar"></span> <span class="icon-bar"></span> <span class="icon-bar"></span> </button> <p class="navbar-brand">Patiobar</p> </div><!-- End navbar-header --> <div class="text-center collapse navbar-collapse" id="stations"> <button type="button" ng-repeat="station in stations" class="btn btn-default navbar-btn btn-sm" ng-click="changeStation(station.id);">{{station.name}}</button> </div> </div> <!-- End container-fluid --> </nav> <div class="container" ng-controller="SongController"> <div id="player" class="center-block"> <div class="text-center"> <img class="center-block img-rounded img-responsive" id="coverArt" ng-src="{{src}}" alt="{{alt}}"> <div id="details"> <p id="title" class="media-heading">{{title}}</p> <p id="albumartist">{{albumartist}}</p> </div> <div id="controls"> <button type="button" id="love" class="pull-left btn btn-default" ng-click="sendCommand('+');"> <span class="glyphicon glyphicon-thumbs-up"></span> </button> <button id="pauseplay" type="button" class="btn btn-default" ng-click="sendCommand('p');"> <span class="glyphicon glyphicon-pause"></span> </button> <button type="button" class="btn btn-default" ng-click="sendCommand('n');"> <span class="glyphicon glyphicon-fast-forward"></span> </button> <button type="button" class="btn btn-default" ng-click="sendCommand('(');"> <span class="glyphicon glyphicon-volume-down"></span> </button> <button type="button" class="btn btn-default" ng-click="sendCommand(')');"> <span class="glyphicon glyphicon-volume-up"></span> </button> <button type="button" class="pull-right btn btn-default" ng-click="sendCommand('-');"> <span class="glyphicon glyphicon-thumbs-down"></span> </button> </div> </div> <!-- End text-center --> </div> <!-- End Player --> </div> <!-- End container (SongController) --> <script src="/socket.io/socket.io.js"></script> <script src="/js/jquery-2.1.1.min.js"></script> <script src="https://ajax.googleapis.com/ajax/libs/angularjs/1.2.22/angular.min.js"></script> <script src="/js/bootstrap.min.js"></script> <script src="/js/main.js"></script> </body> </html>
<img class="center-block img-rounded img-responsive" id="coverArt" ng-src="http://cont-sv5-1.pandora.com/images/public/rovi/albumart/1/2/9/6/074640926921_500W_500H.jpg" alt="Sounds Of Silence" src="http://cont-sv5-1.pandora.com/images/public/rovi/albumart/1/2/9/6/074640926921_500W_500H.jpg">
