Jon,
The values don't show up in HS3 when using the following:
Pattern1=(?s)<td width="34%" class="dataName"><span id="langLastBatteryXfer">Last Battery Transfer</span>:</td><td colspan="3">.*?</td>(.*?)</td> Pattern2=(?s)<td class="dataName"><span id="langInternalTemp">Internal Temperature</span>:</td><td colspan="3">.*?F</td>(.*?);F</td> Pattern3=(?s)<td class="dataName"><span id="langRuntimeRemaining">Runtime Remaining</span>:</td><td colspan="3">.*?</td>(.*?)</td> Pattern4=(?s)<td class="dataName"><span id="langInputValtage">Input Voltage</span>:</td><td colspan="2">.*?;<span id="langVAC">VAC</span></td>(.*?);<span id="langVAC">VAC</span></td> Pattern5=(?s)<td class="dataName"><span id="langOutputVoltage">Output Voltage</span>:</td><td colspan="2">.*?;<span id="langVAC">VAC</span></td>(.*?);<span id="langVAC">VAC</span></td>
