Does anybody have a step by step to get this plugin working properly? I am using version 3.6.5.0. The hub works outside of the plugin. I tried both with and without the login credentials as suggested by another member. This did not work.
Plugin: Harmony Hub Test Get Active Activity output for:Hub1: LOGITECH WEB SERVICE LOGIN : FAILURE ERROR : harmonyWebServiceLogin : Logitech web service response does not contain a login authorization token -
Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
