Go Back   HomeSeer Message Board > Thermostat / HVAC Plug-ins > Thermostat / HVAC Discussion
Old August 31st, 2017, 03:50 PM
gtrguy gtrguy is offline
Variable Speed Trane/Lennox/Anything Plugin?
Are there any plugins that work with the variable speed hvac systems? Seems like our only real option is a two or 3 stage system with nest.
Old September 12th, 2017, 12:06 PM
Seems like there are a ton of people that want to control trane or lennox or anything variable speed but cant with the current state of plugins.
Old September 12th, 2017, 12:43 PM
Richel Richel is offline
As a work-around, I am using IFTTT to get HomeSeer to control my Trane (Nexia) systems. It is a bit cumbersome, but it works.
Elliott
Old September 12th, 2017, 01:02 PM
vasrc's Avatar
vasrc vasrc is offline
Most of the variable speed controls nowadays are controlled internally to ensure proper airflow, energy savings, etc. What did you want to do in particular that the current thermostats are unable to do?
Z
Old September 13th, 2017, 05:04 PM
Trying to do? Integrate with homeseer so I can monitor and change settings.
Old September 13th, 2017, 05:08 PM
Elliott
what functionality do you have with it? Is it only a 1 way street (i.e. can set temp but cant get current temp?)
Old September 13th, 2017, 07:02 PM
S-F's Avatar
S-F S-F is online now
Z
To everyone asking.... THIS!
Why would you want to get yourself into a proprietary system when you don't need to? With the Trane Z-Wave thermostats I have you can control a ground source or air source heat pump! I put one on a Waterfurnace that has an inverter compressor not too long ago.
Originally Posted by rprade View Post
Old September 13th, 2017, 07:36 PM
vasrc's Avatar
Look at the XR524 (Homeseer) and XR624. They do both control and monitoring and work on Zwave. I doubt there's anything about your system they won't provide for you. They're a bit of a pain with DST and time keeping, but there's a simple workaround for that.
Z
Old September 13th, 2017, 08:49 PM
Yes, unfortunately, it is a one-way street. I do have Aeon Tech Energy Meters on the HVAC to determine when the HVAC is running and when it is idle. I use this information to control ceiling fans. Elliott
Old January 7th, 2018, 11:10 PM
tome10's Avatar
tome10 tome10 is online now
I have Lennox iComfort, and I consulted with an HVAC guy, and he informed me that my furnace is a Carrier, and it has a variable speed motor, but the variable speed is controlled by the Carrier motherboard which is on a timer of some sort. If the target hasn't been reached within a certain amount of time, the motor speeds up. The Lennox interface box is 'supposedly' only acting as an off/on with no logic involved. I do have Lennox Condensers, so maybe the 'Special' Lennox iComfort is more involved with the cooling. I'll probably need another opinion before I pull the trigger on something else, but this non-zwave HVAC is in my crosshairs. I'm just not informed enough to know what the iComfort is doing that's so 'Special' other than the thermostat itself is very pretty on the wall.
HTML code is On
Lennox wifi iComfort davebanas Thermostat / HVAC Discussion 16 April 2nd, 2018 10:18 PM
Lennox iComfort WIFI Thermostat tome10 IPThermostat 0 October 8th, 2016 01:03 AM
Plugin status variable pyspilf BLML2HS (3P) 4 November 3rd, 2015 06:54 AM
ETA for Zwave (Thermostat Trane) Plugin pdixon HS3 / HS3PRO Discussion 12 August 5th, 2015 10:55 AM
INSTEON and Variable Speed Pool Pump swanie2000 Lighting & Primary Technology Discussion 7 May 14th, 2015 08:50 PM
