Originally posted by whydna
View Post
HS-WD100+ Ramp Rate Question
This is not what I expected
This isn't good.
I just installed a 5-Pack of these and in 2 locations - I Do Not Want a Ramp - At All. There will be additional locations that also should not have a ramp.
The switches these are replacing (Leviton Vizia RF +) were able to be set "at the switch".
Perhaps these have the same ability but it isn't publicized? I can't hardly imagine I would be moving backwards by installing these. I'm going to drop a but-load of cash on new switches but they need to have the basics!
Are there comparable switches from another vendor? I was able to find another brand but they appear to be the same switch (Only Less $$ Cheaper). I went ahead and bought one to check it out.
https://forums.homeseer.com/showpost...5&postcount=36HS4 Pro on Shuttle NC10U, Win10; Z-NET
Number of Devices: 1005
Number of Events: 293
Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
Originally posted by wsume99 View Post...when anyone else in my house turns the switch on or off they think it is not working and they hit it again, multiple times. Often they end up activating the dim function when doing this...HS4 Pro on Shuttle NC10U, Win10; Z-NET
Originally posted by jmaddox View Post
SOLVED
Originally posted by whydna View PostWhen I press the switch on, the light immediately turns on with no ramping, yay! When I press the switch off, the light fades off instead of turning off instantly.
Thoughts?
I had the exact same issue. I have a callback script which watches for the tap up and tap down events on the central scene, looks up the dimmer associated with the scene device, and sends a remote on or off command. Same behavior: On works instantly, but Off slowly ramps down. The issue here is that you have to change the state with your remote command for it to have any effect. When you tap the switch up, the device is processing the "Last" command, so a remote command of "On" will override that and count as a remote command, using the remote ramp rate. BUT, when you tap the switch down, the switch is processing the "Off" command, and sending another "Off" command remotely is ignored because it's already performing an "Off" command.
The solution is to send another, different command, and then "Off", so that the "Off" counts as a remote command. I've tried both "Off" and "Dim 1%", and they both work great. I recommend putting another filter on your event to check that the device isn't already off, or it will turn it on/off again. In my script, I just check that the device value is non-zero.
Room management callback script
Originally posted by dhennen View PostWould you be able to share that script?
* Every switch and dimmer has two "scene" settings, "High" and "Low", defaulting to "On" and "Off" respectively
* Tapping Up/Down sets it to the "High"/"Off" setting, unless it's already there, in which case it's set to "On"/"Low"
* Double tap Up/Down sets everything in the room to the "High"/"Low" scene
* Triple tap Up/Down sets the saved "High"/"Low" setting for that switch or dimmer to its current setting
This lets me set an entire room to all the High scene (which defaults to On), or all the Low scene (which defaults to Off), with just one double tap on any switch for that room. If I want to override any particular switch's behavior for a scene, I can change it directly from the switch or dimmer, no code or even homeseer config changes necessary. For instance, I set the cabinet underlighting to always stay on by setting its "Low" value to "On", and I set my super-bright dining chandelier to only go to 70% by setting its "High" value to "Dim 70%", all from the switches themselves.
I bothered to code this all up because the new house I bought has switches in the most horrible of locations -- In every common room, in order to turn all the lights on or off, I'd have to walk around the entire room to all the switch banks. The house has 73 switches...I don't know what the electrician was thinking.
I'm not particularly proud of the code, but it works. Here's its current incarnation (just run the Main function in startup.vb to register it as the callback):
Code:Imports System.Collections.Generic Imports Scheduler.Classes Sub Main(parm As Object) hs.WriteLog("callback", "Registering status change callback") hs.RegisterStatusChangeCB("callback.vb", "StatusChangeCB") End Sub Function GetRoomSwitchRefsProxy(ByVal Parms as String) Dim Location As String() = Split(Parms, "|") GetRoomSwitchRefsProxy = GetRoomSwitchRefs(Location(0), Location(1), CBool(Location(2))) End Function Function GetMatchingDeviceRefs(ByVal Predicate As Func(Of DeviceClass, Boolean)) As Integer() Dim Refs As List(Of Integer) = New List(Of Integer) Dim Devices As clsDeviceEnumeration = hs.GetDeviceEnumerator Do Dim Dev As DeviceClass = Devices.GetNext If Predicate(Dev) Then Refs.Add(Dev.Ref(hs)) Loop Until Devices.Finished Return Refs.ToArray() End Function ' Predicates for switch types Function IsDimmer(ByVal Dev As DeviceClass) As Boolean Return Dev.Device_Type_String(hs) = "Z-Wave Switch Multilevel" End Function Function IsBinary(ByVal Dev As DeviceClass) As Boolean Return Dev.Device_Type_String(hs) = "Z-Wave Switch Binary" End Function Function IsSwitch(ByVal Dev As DeviceClass) As Boolean Return IsDimmer(Dev) Or IsSwitch(Dev) End Function Function GetRoomSwitchRefs( _ ByVal Floor As String, _ ByVal Room As String, _ Optional ByVal IncludeBinary As Boolean = false) Dim Refs As List(Of Integer) = New List(Of Integer) Dim Devices As clsDeviceEnumeration = hs.GetDeviceEnumerator Do Dim Dev as Classes.DeviceClass = Devices.GetNext If Dev.Location(hs) = Room And Dev.Location2(hs) = Floor If IsDimmer(Dev) Or (IncludeBinary And IsBinary(Dev)) Then Refs.Add(Dev.Ref(hs)) End If Loop Until Devices.Finished Return Refs End Function ' Finds a particular device type in a device group. Returns first match. Function GetRelatedDeviceRef(ByVal Ref As Integer, ByVal DeviceTypes As String()) As Integer ' Find the parent device Dim pRef As Integer = hs.GetDeviceParentRefByRef(Ref) If pRef = 0 Then pRef = Ref Dim pDev = hs.GetDeviceByRef(pRef) ' Find the corresponding device, if any Dim cRefs = pDev.AssociatedDevices(hs) For Each cRef As Integer In cRefs Dim cDev As DeviceClass = hs.GetDeviceByRef(cRef) Dim cDeviceType As String = cDev.Device_Type_String(hs) For Each DeviceType As String In DeviceTypes If DeviceType = cDeviceType Then Return cRef Next Next Return 0 End Function Function GetSwitchRef(ByVal Ref As Integer, Optional ByVal IncludeBinary As Boolean = true) As Integer Dim DeviceTypes As String() If IncludeBinary Dim DeviceTypes As String() = {"Z-Wave Switch Multilevel", "Z-Wave Switch Binary"} Return GetRelatedDeviceRef(Ref, DeviceTypes) Else Dim DeviceTypes As String() = {"Z-Wave Switch Multilevel"} Return GetRelatedDeviceRef(Ref, DeviceTypes) End If End Function Function ControlDevice(ByVal Ref As Integer, ByVal Status As String) As CAPIControlResponse Dim Control As CAPI.CAPIControl = hs.CAPIGetSingleControl(Ref, false, Status, false, false) Dim Current As CAPI.CAPIStatus = GetStatus(Ref) 'hs.WriteLog("callback", "ControlDevice: Setting device " & Ref & " from " & Current.Status & " to " & Status) ' Short circuit on invalid status or no-op If Control is Nothing hs.WriteLog("callback", "ControlDevice: Device " & CStr(Ref) & " unknown control: " & Status) Return CAPIControlResponse.All_Failed End If If Control.Label = Current.Status Then Return CAPIControlResponse.All_Success ' Actually set device to requested state Return hs.CAPIControlHandler(Control) End Function Function GetControl(ByVal Ref As Integer, ByVal Status As String) As CAPI.CAPIControl Dim Control As CAPI.CAPIControl = hs.CAPIGetSingleControl(Ref, false, Status, false, false) If Control is Nothing hs.WriteLog("callback", "GetControl: Device " & CStr(Ref) & " unknown control: " & Status) End If Return Control End Function Function GetStatus(ByVal Ref As Integer) As CAPI.CAPIStatus Return hs.CAPIGetStatus(Ref) End Function ' Save the current value of the device as the given scene Sub SaveScene(ByVal Ref As Integer, ByVal Scene As String) Dim Status As String = GetStatus(Ref).Status Dim Dev = hs.GetDeviceByRef(Ref) hs.WriteLog("callback", "Saving status """ & Status & """ as scene """ & Scene & """ for device " & _ CStr(Ref) & ": " & Dev.Location2(hs) & " " & Dev.Location(hs) & " " & Dev.Name(hs)) hs.SaveINISetting(CStr(Ref), Scene, Status, "callback.ini") End Sub ' Get the control corresponding to the given device's given scene Function GetSceneControl(ByVal Ref As Integer, ByVal Scene As String, ByVal Fallback As String) As CAPI.CAPIControl Return GetControl(Ref, GetScene(Ref, Scene, Fallback)) End Function ' Retrieve the saved value of the device for the given scene, with given default Function GetScene(ByVal Ref As Integer, ByVal Scene As String, ByVal Fallback As String) As String Return hs.GetINISetting(CStr(Ref), Scene, Fallback, "callback.ini") End Function Sub StatusChangeCB(ByVal Parm As Object()) 'Parse the parameters If Parm Is Nothing Then Exit Sub If Parm.Length < 5 Then Exit Sub Dim Code As String = "" Dim Address As String = "" Dim OldVal As Double Dim NewVal As Double Dim Ref As Integer Dim Dev As Object Try Code = Parm(0).ToString Address = Parm(1).ToString NewVal = Parm(2) OldVal = Math.Abs(Parm(3)) 'we set this to negative to trigger future callbacks Ref = Parm(4) Dev = hs.GetDeviceByRef(Ref) Catch ex As Exception hs.WriteLog("Stat_Change.VB", "Error, Exception parsing Parm: " & ex.Message) Exit Sub End Try ' We only care about the Scene management for HomeSeer dimmers If Dev.Device_Type_String(hs) <> "Z-Wave Central Scene" Then Exit Sub ' Single tap up/down will set switch to saved High/Off scene, or On/Low if already at scene ' Double tap up/down will set room to High/Low scene ' Triple tap up/down will save current switch value as High/Low scene setting for switch Try ' Set the original scene to an the negation of the real value, so that future presses work. ' (Callback is only called on *change* of the value). Don't trigger other events on this, though. hs.SetDeviceValueByRef(Ref, -NewVal, False) ' Figure out what we want to do Dim Controls As List(Of CAPI.CAPIControl) = New List(Of CAPI.CAPIControl) Select Case NewVal Case 1000 'single tap up Dim cRef = GetSwitchRef(Ref, false) If cRef = 0 Then Exit Sub Dim Status As String = GetStatus(cRef).Status Dim Scene As String = GetScene(cRef, "High", "On") If Scene = Status Then Scene = "On" Controls.Add(GetControl(cRef, Scene)) Case 2000 'single tap down Dim cRef = GetSwitchRef(Ref, false) If cRef = 0 Then Exit Sub Dim LastChanged As Date = hs.DeviceLastChangeRef(Ref) Dim cDev As DeviceClass = hs.GetDeviceByRef(cRef) Dim cValue As Double = cDev.devValue(Nothing) Dim cLastChanged As Date = cDev.Last_Change(Nothing) Dim Scene As String = GetScene(cRef, "Low", "Off") ' If on (or changed in the last 3 seconds), then turn it off If cValue <> 0 Or cLastChanged.AddSeconds(3) > LastChanged Scene = "Off" ' For "remote rate" dim to off we need to send a "different" intermediate command ' But don't bother if it's really close to off already anyway If cValue > 10 Controls.Add(GetControl(cRef, "Last")) End If End If Controls.Add(GetControl(cRef, Scene)) Case 1003 'double tap up For Each cRef As Integer In GetRoomSwitchRefs(Dev.Location2(hs), Dev.Location(hs), true) Controls.Add(GetSceneControl(cRef, "High", "On")) Next Case 2003 'double tap down For Each cRef As Integer In GetRoomSwitchRefs(Dev.Location2(hs), Dev.Location(hs), true) Controls.Add(GetSceneControl(cRef, "Low", "Off")) Next Case 1004 'triple tap up SaveScene(GetSwitchRef(Ref), "High") Case 2004 'triple tap down SaveScene(GetSwitchRef(Ref), "Low") End Select ' For Each Control As CAPI.CAPIControl In Controls ' hs.WriteLog("debug", "Device: " & Control.Ref & " Control: " & Control.Label) ' Next If Controls.Count > 0 hs.CAPIControslHandler(Controls.ToArray()) End If Catch ex As Exception hs.WriteLog("callback", "Exception occurred: " & ex.Message & "stacktrace:" & ex.StackTrace) Exit Sub End Try End Sub
Solution
Originally posted by julez View PostI've got the same issue, were you able to figure out a way for the off without fading?
Scene 001 Key Pressed => Set multilevel switch to On
Scene 002 Key Pressed => Set multilevel switch to Dim 1%, then set multilevel switch to Off
