question...
Trying to go back and get my x10 working so just started with the basics..
since fresh install get working what I know works..
anyway...
my issue which will lead to the question.
I have a edgeport/4
http://www.digi.com/products/usb-and...-hubs/edgeport
have (long story on com port numbers for another thread)
port 1 Com35 - concord 4 alarm - functioning
port 2 Com36 - ztroller - functioning
port 3 Com37 - w800
port 4 Com38 - ti103
so going down the line I got to the w800. Set it up and using a palm pad will not do anything. Turn logging on and nothing.
so I decide to throw the w800 on the onboard serial port (com1) - change in blrf to com1 and viola works. Ok palmpad button hit and log shows H2 On
Move w800 back to com37 - set blrf to 37 and still not working.
so thinking the com port is bad I moved it to 38, 35 and 36 no dice.
I have a 4 port SII PCI serial card so installed it, downloaded drivers.
Tried w800 on it and cant get it to go.
move back to COM1 onboard and all good.
I am clueless but one thing I do know is that Com1 opens... other ports don't.
could it be your plugin doesn't check that high of com ports?
if you notice every time I set the port in BLRF to something different... it will close said port (38, 40 etc)
but if I use Com1 then it will open it and if I change it to 35 then it shows com1 port closed....
anyway...
I have a edgeport/4
port 3 Com37 - w800
Feb-10 11:12:18 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM1) Open Feb-10 11:12:17 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM39) Closed Feb-10 11:04:05 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM38) Closed Feb-10 11:02:37 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM40) Closed Feb-10 11:01:32 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM1) Closed Feb-10 11:00:07 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM1) Open Feb-10 11:00:06 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM40) Closed Feb-10 10:57:49 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM1) Closed Feb-10 10:55:19 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM1) Open Feb-10 10:55:18 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM40) Closed Feb-10 10:53:28 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM1) Closed Feb-10 10:49:51 PM BLRF Info Receiver #1 - WGL W800RF32 Receiver (COM1) Open
