Hi Everyone,
Is it possible with this plug-in and Hue bulbs to mimic dim/brighten behavior of a traditional HS-WD100+ and standard bulb combo? I'd be using the HS-WS100+ switch and its "Press & Held" and "Released" statuses.
For example; when the bottom paddle is held continually drop the brightness of the hue bulb by some X% every Y seconds until released. It feels like it may be some kind of DO WHILE loop, but thought I'd ask if you had any thoughts. I have some Hue bulbs on the way to play with and this is more than likely the plug-in I'd choose if I decided to keep them and integrate them.
Thank you.
Thank you.
