Thanks for the quick update, but I'm looking for the present UV index (for my sprinkler system).
Environment Canada Weather plugin - HS3
I started to get some errors on the HS3 console & startup log since the last update. Seems to be working ok and updating. Is this some sort of issue?
May-26 23:15:41 Plug-In Finished initializing plug-in EnvCan
May-26 23:15:40 envcan Config file: C:\Program Files (x86)\HomeSeer HS3\Config\EnvCan_config.xml
May-26 23:15:40 Info Plugin EnvCan has connected. IP:127.0.0.1:49890
May-26 23:15:33 Plug-In Found plug-in: EnvCan, version: 3.0.0.17
May-26 23:15:33 Error Error, Class not found in plugin EXE, maybe namespace is not correct,? Note filename is case sensitive!: HSPI_ENVCAN (2).exe Class: HSPI_ENVCAN (2).HSPI->
May-26 23:14:01 Info Plugin EnvCan with instance: has disconnected
May-26 23:14:01 Shutdown Shutting down plug-in: EnvCan
Current Date/Time: 2017-05-26 23:23:33
HomeSeer Version: HS3 Standard Edition 3.0.0.318
Operating System: Microsoft Windows 10 Home - Work Station
System Uptime: 0 Days 0 Hours 8 Minutes 0 Seconds
IP Address: 192.168.0.XX
Number of Devices: 184
Number of Events: 21
Available Threads: 400
Enabled Plug-Ins
3.0.0.17: EnvCan
3.0.0.68: HSTouch Server
1.0.17123.357: MyQ
3.0.1.110: Z-Wave
Originally posted by MikeO3 View PostI started to get some errors on the HS3 console & startup log since the last update. Seems to be working ok and updating. Is this some sort of issue?
Let me know if you need more information. Thanks for a good plugin BTW!
Enabled Plug-Ins
3.0.0.17: EnvCan
1.0.17123.357: MyQ
3.0.1.110: Z-Wave
Can you confirm only one version of the plugin is in the HS3 folder and rename it to not have the (2) in the filename and let me know what happens.
Sent from my SM-T810 using Tapatalk
Originally posted by chrisgo View PostLooks like you might have multiple versions of the plugin in the HS3 folder. The executable should not have (2) in the filename.
Originally posted by chrisgo View PostI have a created a HS3 plugin that can read the Environment Canada ATOM feeds and create HS3 devices that can be used in HS Touch etc.
HSPI_ENVCAN_3.0.0.4.zip
To configure, just add your ATOM feed (eg https://weather.gc.ca/rss/city/ab-52_e.xml) to the feeds page and use a unique prefix.
A bunch of HS3 devices will be created. Each device has an associated weather icon as defined in the parse configuration page. This can be used in HS Touch as a status image.
A background image can be added to the /html/images/envcan/backgrounds folder to represent the state of the current weather. I am using this image as a background in HS Touch.
I've included an example config file which has my parse rules but you can start from scratch if you prefer.
The icons folder has some weather icons that can be replaced with whatever you prefer.
No background images are supplied as I don't have anything royalty free.
Question for you - is there a way to query POP (Probability of Precipitation) in the upcoming forecasts? That would enable me to, for example, only run the lawn sprinkler if the POP were less than 50% today and tomorrow.
Atom feed in french
Hi guys,
Very nice plug-in Chrisgo.
While configuring it, I have issues with the Atom feed; when I use the english format : https://weather.gc.ca/rss/city/qc-148_e.xml it works flawlessly. If I try variations to get a french feed like https://weather.gc.ca/rss/city/qc-148_f.xml or https://meteo.gc.ca/rss/city/qc-148_f.xml it does not work . Could someone point me the right format for the french feed?
This the error I found in the log: error in feed: https://meteo.gc.ca/rss/city/qc-148_f.xml - Object reference not set to an instance of an object
The feed https://weather.gc.ca/rss/city/qc-148_f.xml works fine for me using version 3.0.0.17.
Can you please send me your EnvCan_config.xml from the Config folder so I can re-create?
Chris
Hi Chrisgo!
Just installed your plugin (3.0.0.17), and all seems good, with a couple of exceptions I'm seeing in the log:
Code:Jul-29 11:27:24 PM Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\images\envcan\backgrounds\ Jul-29 11:27:24 PM Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\images\envcan\backgrounds\clouds.jpg Jul-29 11:27:23 PM Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\images\envcan\backgrounds\sunny.jpg
also, seeing this repeatedly in the log, which just stared after the install:
Code:Jul-29 11:25:30 PM HSTouch Server Warning Exception on Value Change callback: Object reference not set to an instance of an object. Jul-29 11:25:30 PM HSTouch Server Warning Exception on Value Change callback: Object reference not set to an instance of an object. Jul-29 11:25:29 PM HSTouch Server Warning Exception on Value Change callback: Object reference not set to an instance of an object. Jul-29 11:25:29 PM HSTouch Server Warning Exception on Value Change callback: Object reference not set to an instance of an object.
thanks for the great plugin - and I have to ask... is Chrisgo a play on an "oil" gag?
thanks,
dave
(in Ottawa, ON)
