Yes it will! I have been looking at the protocol docs and it seems like things are straightforward.
Audio on HAI Panel?
Originally posted by avpman View PostBasic commands Via Alexa too?
Sent from my SM-G935V using TapatalkHS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Originally posted by rmasonjr View PostThat is going to be tricky with the current Connected Home API. I dont think audio is supported. That said, I would suspect Alexa will continue to grow and hopefully provide expanded controls.
Originally posted by avpman View PostHopefully you're right. I'm only using HS ZEE now so I can get the Alexa functionality. I've had to create a bunch of User Buttons to do basic Audio control.HS4Pro on a Raspberry Pi4
Guest
I have HAI HI-FI 2 with 16 zones with 4 Sonos as my inputs. Currently using buttons and flags to control using Alexa and of course with programing thru Dlr. PC Access.
Here have Russound CAA boxes (3). Over the years purchased a serial server such that I could control the CAA with either the OP2 panel or software (and used Homeseer here for software).
Fastest connectivity / control has always been the Russound keypad controllers (Use KPL here). Next was the OmniTouch 5.7 and Omnitouch 5.7e's which are slower than the keypads so I do not use them much for Russound control. Played with HS2 a bit and it was never fast enough for me.
The above said it would be nice to offer the basics of the OmniPro 2 panel audio hardware control as it does work Ok with the Omnitouch screens.- Pete
Originally posted by Pete View PostHere have Russound CAA boxes (3). Over the years purchased a serial server such that I could control the CAA with either the OP2 panel or software (and used Homeseer here for software).
I think we're all in consensus as to basic functionality. I think base/treble/left/right,etc could, if ever, come later. My biggest need is for basic Alexa functionality. i.e. "Turn on Bedroom Audio <zone>," "Set Bedroom Audio to XM <source>" and the really hard one "Press bedroom Audio keys Six Three Zero" (to change stations.) The HAI SDK documentationn provides for limited control anyway and that's going to be the limiting factor:
AUDIO SOURCE PROPERTIES
Data 4-16 source name
AUDIO ZONE PROPERTIES
Data 4 on/off (0-1)
Data 5 source (1-n)
Data 6 volume (0-100)
Data 7 mute (0-1)
Data 8-20 zone name
As the panel converts these commands into the correct commands required by the specific audio system attached to it (and defined in the serial port setup.)
All of the commands are generic and similiar to the units (whether units are x10, upb, zwave, zigbee...)
Yeah here used the main floor all speaker on during family get togethers and source it over to the Kodi box by the family room LCD / AVR (AVR is one source for the Russound). Family room, hallway, dining room, living room, kitchen, deck and garage. Just used on and off and source control. Didn't much play with rest of the stuff cuz once it is set you do not need to touch it. Utilize Russound outdoor speakers for garage and deck. Exposed to the sun/rain/snow on the deck for some 6 years + now with effects on the speakers. Neighbor put his controller in a box with a plastic cover on it on the deck house wall. I put mine inside next to the door to the deck. The hardest part was drilling in to the brick and running the cables down to the basement here. But did the same for CCTV on the first floor level brick.- Pete
Any updates?
I recently scrapped my big HAI OmniProII system -- forklift upgrade to HS3. I couldn't be happier.
I have a HiFi2 w/16 output zones. Luckily I am able to run this system independent of the OmniProII. I'm looking for a plugin that will support this and integrate with any audio capabilities within HS3.
Please let me know if you have anything available for integration. I am also happy to dig in and write some code in assistance.
Craig
This seems to be the latest thread on audio support (Hi-fi2) within the Omni plug-in. I am looking to pick a new whole audio system and leaning towards the Hi-fi2 as I already have the Omni Pro. I know there are other more modern solutions but I like what the HIFI2 has to offer at the price.
Has the audio support notion been abandoned?
Originally posted by mhog View PostThis seems to be the latest thread on audio support (Hi-fi2) within the Omni plug-in. I am looking to pick a new whole audio system and leaning towards the Hi-fi2 as I already have the Omni Pro. I know there are other more modern solutions but I like what the HIFI2 has to offer at the price.
Sent from my SM-G935U using TapatalkHS4Pro on a Raspberry Pi4
Originally posted by rmasonjr View PostI might have asked this before, so I apologize, but what audio model are you using with your panel? Number of zones?
Thanks Rob!
<style></style>Last edited by avpman; January 14, 2018, 10:07 AM.
